Generator Interlock Kit For GE Load Center - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-08-2012, 07:27 PM   #16
Thumbs up
Help Scott!
I see you are right now heading down the same path with exactly the same main panel I have. What interlock ended up working for you? Eagerly awaiting your reply.
Jetmakr, you work at Pratt?
Taylor
Tenacious-T is offline   Reply With Quote
Old 11-08-2012, 09:14 PM   #17
Hi Taylor,
I used the THQLLX1 interlock and it worked out fine. The determining factor is if your main breaker shuts off moving horizontally the THQLLX1 is the one. If the main breaker moves vertically and the generator breaker moves horizontally the THQLLX4 is the one you need. Worked great and is sooooooooooooooooooo much cheaper than a transfer switch.
Pratt.yep. retired after 42 yrs..............
jetmakr is offline   Reply With Quote
The Following User Says Thank You to jetmakr For This Useful Post:
Tenacious-T (11-09-2012)
Old 11-09-2012, 07:56 PM   #18
I don't think your recommendation works with all GE panels
, I think your THQLLX4 solution only works with GE TSM415 or TSM420 main panels though I'm not completely sure. Unless someone tells me these interlock kits are rather universal I don't think it'll work for my and Scott's TM3220CCU or TLM3220CCU main panel.
Congrats on making it 42 years with the eagle!
Old 12-04-2012, 01:41 PM   #19
I've been down the same path this thread is about. The THQLLX4 is for meter main panels. The main is vertical throw and the sub-breaker beneath is vertical throw. GE does not have an interlock kit for MB Goldmark panels that are vertical main throw with branch circuit horizontal throw as the original poster shows in his picture. You'll have to go with the product by Interlockkit.
cheyenne is offline   Reply With Quote
Old 12-05-2012, 07:10 PM   #20
Rewards Points: 272
Originally Posted by jetmakr View Post
Hello folks,
Looking into getting a backup generator for my house. I have a GE PowerMark Gold 200A service and notice that they sell a generator interlock kit instead of using a transfer panel. I am wondering if I have a problem because the electrician who installed my panel put it in upside down. Any advice would be appreciated.
I have the exact same panel and I'm also planning on buying the interlock kit.
A couple of year ago I got an interlock kit for a Square D QO breaker box for practically nothing on clearance at Lowes. I still have it. I wish I knew someone that would trade a GE interlock kit for the QO kit I have.
speedster1 is offline   Reply With Quote
Old 12-10-2012, 10:26 PM   #21
Rewards Points: 255
Taylor
I still haven't done this yet. Storm took down a fence so even with insurance, I'll be out of pocket quite a few $$$ to fix that. So genset, etc. may have to wait until Spring. You know... after the winter when I would most like to have it handy. : )
Scottg is offline   Reply With Quote
Square D load center QO20M100 LAA2of3 Electrical 33 05-11-2015 12:28 PM
Load center & grounding recommendations lesp Electrical 9 04-16-2011 12:14 AM
Load center vs. bottom fed Panel Board. Ugh. wmldwilly Electrical 8 04-23-2009 08:48 PM
CH42B200R Load Center for Detached Home Theater nomad4137 Electrical 6 07-21-2008 07:57 PM
Main Load center Size Evnldr Electrical 11 06-13-2008 11:10 PM
