Generator Install - Electrical - DIY Chatroom Home Improvement Forum
Old 05-17-2013, 01:55 AM   #1
Rewards Points: 512
Generator Install
About to do one, so question about the Main panel to Automatic Transfer Switch (ATS) wiring.
How are the individual branch circuits setup in the ATS? Are the breakers from the panel transferred into the ATS, or do they just go unused? Or, do they have a connection back to the ATS?
So far, my understanding is that there will be a 50-70a DP to put into the Panel, to protect the ATS, but I can't get a clear picture of each branch circuit transfer.
From what I've seen in videos, so far, it's ambiguous.
Installation is the Reverse of Removal.
Old 05-17-2013, 02:43 AM   #2
Electrical Contractor
kbsparky's Avatar
If the "transfer switch" has breakers in it for individual circuits, then the existing breakers in the present panel will become unused.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
Philly Master (05-17-2013)
Old 05-17-2013, 03:01 AM   #3
Rewards Points: 512
kb, Would you watch these videos? My question in this first video starts at 6:48. The 2nd video starts at the beginning, and goes to about 1:08.
Here, I can't tell if they're leaving the panel breaker unused, or reconnecting it with a RED wire from the Transfer Switch.
The Genny and ATS is Generac 14Kw
Thanks for helping.
http://www.youtube.com/watch?v=Sk2D3...SW7ZUQ&index=2
http://www.youtube.com/watch?v=-Kis7...SW7ZUQ&index=1
Old 05-17-2013, 05:20 AM   #4
Philly Master's Avatar
Rewards Points: 516
unused .... correct.. first you must be using the "EASY SWITCH"
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 05-17-2013, 06:24 AM   #5
Rewards Points: 516
just FYI ...
there are a couple of things to watch for ..
1) disconnect ... some say the breaker on the GEN is not a disconnect ...
2) labeling of the service/meter that there is a generator on site and disconnecting the service may energize the house ..
3) the whips supplied with the EASY SWITCH are sometimes not long enough or are the wrong type for outside ...LOL
Old 05-17-2013, 09:13 AM   #6
Rewards Points: 512
Well, it's called "SMART SWITCH". Same thing?
Let's keep our terms straight here The GEN does not have a breaker; the Transfer Switch and the Panel do
Gotcha!
Old 05-17-2013, 10:08 AM   #7
Rewards Points: 1,534
My computer can't play videos (download too long) so I may be making redundant comments.
For a transfer switch unit with individual transfer switches for each branch circuit, you unhook a wire from a breaker in the panel and connect it to one of a pair of wires (whips) coming from the transfer switch unit. You connect the other wire of the pair to the panel breaker. Use wire nuts and pigtails (short lengths) if the wires don't reach. In a way each transfer switch hookup resembles a switch loop.
For generator operation the transfer switch unit provides (or should provide) overcurrent protection for each branch circuit it serves for example each transfer switch may have a built in breaker. When the individual transfer switch is flipped to the "utility power" position the original panel breaker provides overcurrent protection for that branch circuit.
The generator breaker acts as a "master breaker" during generator operation.
The generator cannot energize the main panel or any branch circuit that is not run through the transfer switch unit.
Old 05-17-2013, 03:26 PM   #8
Rewards Points: 516
Gotcha!
1) you decide ... ... http://www.generac.com/Residential/T...uit/EZ_Switch/
2) on the left side of the generator there is a door .... What's behind door #1
Old 05-17-2013, 03:30 PM   #9
Rewards Points: 516
Thanks for helping.
Just to clarify you have this kit ... # 5872 and ..
http://www.generac.com/Residential/GuardianSeries/14kW/
and FYI see the door on the right side of gen ???
Old 05-17-2013, 04:36 PM   #10
Rewards Points: 31
Mine does.
rjgogo is offline   Reply With Quote
Old 05-17-2013, 06:45 PM   #11
Rewards Points: 512
Thanks guys, I got it.
