Generator Inlet That Will Fit In An Electrical Box - Electrical - DIY Chatroom Home Improvement Forum
Old 03-02-2013, 10:25 PM   #1
Electrical Enthusiast
Rewards Points: 504
Generator inlet that will fit in an electrical box
I recently installed a generator interlock kit to go with my panel. Running a wire to an inlet on the outside of the house would have been nearly impossible, due existing electrical/telephone interface "clutter" on that outside wall. I decided to mount an old work single gang box about 2 feet under the panel. It is in a garage about two feet from the garage door, (the panel is across from it diagonally, on an inside wall).
I was hoping to find a female 30 amp twistlock "inlet" that would fit in a single gang box, and basically be flush with the wall. However internet/store searches aren't turning up anything. I thought about wiring a female plug inside the box and just covering it with a blank cover. I also thought about just putting in a twistlock receptacle, but that would require making the dreaded "suicide" cord.
Is there somewhere I could find an inlet that will fit in a single gang box and be flush with the wall?
Kyle_in_rure is offline   Reply With Quote
Old 03-02-2013, 11:22 PM   #2
Electrical Contractor
kbsparky's Avatar
You want a P&S WPG-2, with a flanged inlet:
-KB
The Following 2 Users Say Thank You to kbsparky For This Useful Post:
Kpack (03-03-2013), Kyle_in_rure (03-03-2013)
Old 03-03-2013, 12:44 AM   #3
Rewards Points: 504
That looks perfect, just found one on the internet.
Thanks!
Old 03-03-2013, 02:26 AM   #4
Rewards Points: 160
That looks a lot simpler, easier to mount, and more water-tight than the Reliance boxes that have a slide off cover and stick way out from the wall. Next time!
philS is offline   Reply With Quote
Old 03-03-2013, 11:07 AM   #5
Rewards Points: 82
No "in use" cover?
We have to use them for wet location receptacles. Why not this 30 amp twist lock?
Is it because the receptacle is recessed? Is it rated for wet locations? My inlet has a cover that shields the plug and the receptacle from water or snow.
Old 03-03-2013, 11:10 AM   #6
Rewards Points: 504
Plus it's $40 cheaper.
Old 03-03-2013, 06:14 PM   #7
kbsparky's Avatar
Originally Posted by J. V. View Post
No "in use" cover?
1) This is not a "receptacle"
2) We are not dealing with a 15 or 20 Amp rated device.
-KB
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 07:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 10:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 03:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Usefull Electrical Web Sites PaliBob Electrical 1 02-03-2009 11:49 AM
