Generator Inlet Height - Electrical - DIY Chatroom Home Improvement Forum
Old 09-02-2013, 03:07 PM   #1
Generator Inlet height
Is there a minimum height that a generator inlet box must be off the ground to meet code?
jtd771 is offline   Reply With Quote
Old 09-02-2013, 03:11 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Since you didn't put your location then, I wouldn't put it any lower than your average snowfall is.
If you're in South America, no worries
wirenut1110 is offline   Reply With Quote
Old 09-02-2013, 03:26 PM   #3
Rewards Points: 3,130
Better yet, if snow is a possibility, put it under a covered deck or porch if you have one.
Old 09-02-2013, 03:50 PM   #4
Sorry. Sparta, NJ. It is going in a patio area that has a roof so I'm not worried about the snow height luckily. Just want to make sure it's at the appropriate height to meet code.
Old 09-02-2013, 03:58 PM   #5
Oso954's Avatar
Rewards Points: 1,106
Ask your AHJ if there is a maximum height.
Personally, I like them above waist level. Lets you look up into it without having to lie on the ground or bend like a contortionist. Putting them to low can be a pain.
Oso954 is offline   Reply With Quote
Old 09-02-2013, 04:14 PM   #6
Rewards Points: 510
The OP was asking for a minimum.
Since there is no overcurrent device in the inlet box, there may not be a maximum.
If it's considered a means of disconnect, then I'd say the max height is 6' 7".
Old 09-02-2013, 06:19 PM   #7
Sorry but I'm not familiar with the acronym "AHJ". What does that stand for?
Old 09-02-2013, 06:21 PM   #8
Rewards Points: 510
AHJ= authority having jurisdiction aka inspector
The Following User Says Thank You to wirenut1110 For This Useful Post:
jtd771 (09-02-2013)
Old 09-02-2013, 06:34 PM   #9
Thank you.
Gas Fireplace Flame Height Control chh HVAC 3 09-09-2012 11:22 AM
What should be the height of wall? so roof pitch is 10 feet... vikasintl Roofing/Siding 2 07-04-2012 10:32 PM
Side Yard Setback, Height of Workshop RM575 Building & Construction 10 06-20-2012 09:25 PM
ridge height calculation oxbow Building & Construction 19 01-14-2012 07:26 AM
How to frame new floor to match existing floor height taylor01 Carpentry 4 04-04-2010 08:59 PM
