Generator Inlet Box Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 12-14-2009, 12:38 PM   #1
Generator inlet box wiring
Hi, I am going to wire a 30 amp 4 prong inlet box to my panel. Im am back-feeding it to a 30 amp 220 breaker and have installed the Square D interlock device that will not let me turn on the breaker without turning off the main. My panel is 3 wire. Inside the inlet box there is the x,y,w,g terminals. The G terminal has a green wire running from the terminal to the frame of the inlet box. I was going to run wire from the x and y terminal to the breaker and wire from the w terminal to the neutral bar. Do I need to run a ground wire from the G terminal as well and go to the neutral bar? I have no ground bar. If the inlet box is attached to the panel by metal conduit will this serve the same purpose. Thanks for any help.
pdman is offline   Reply With Quote
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
