Generator Inlet Box - Electrical - DIY Chatroom Home Improvement Forum
Old 11-08-2013, 02:09 PM   #1
generator inlet box
My house had an existing genrator transfer switch and subpanel. The power inlet box wat a 4 prong/20 amp. I have a genereator that has a 3 prong/30 amp outlet. I bought a 3 prong/30 amp inlet box and a 3 prong/20 amp cable. I'm now researching and i'm not sure this is going to work. It looks like the 4 prong is for 240v and the 3 prong is for 120v. In the second picture you can see the black and red connecting. The black connects to the top left of the white wire. The 3rd picture shows the existing inlet box. the 4th picture is the new inlet box 30amp/ 3 prong..
mike.shultz46 is offline   Reply With Quote
Old 11-09-2013, 01:34 AM   #2
dmxtothemax's Avatar
Rewards Points: 5,352
Is the new genny 240v ? Or 120v ? What does the manual say ?
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
Philly Master (11-09-2013)
Old 11-09-2013, 07:34 AM   #3
The manual says 120v 30amp
Old 11-09-2013, 07:49 AM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
The panel and inlet are wired for 120/240V. You generator is not. You will either need a different generator or rewire the panel and inlet. It should also be noted that you cannot run any multi wire branch circuits off of a 120V panel.
Old 11-09-2013, 08:02 AM   #5
What is a multi wire branch circuit?
Old 11-09-2013, 08:11 AM   #6
k_buz's Avatar
2 hots that share a neutral.
Old 11-09-2013, 08:28 AM   #7
my subpanel has 4 circuits currently connected. one powers my boiler cirulation pump,one runs my kitchen outlets,one is for basement circuit and one is for living room circuit. can i install the 3 prong inlet box and power my 4 circuits? none of the items being powered is 240v as far as i know, which is not much.
Old 11-09-2013, 10:17 AM   #8
k_buz's Avatar
You will be very limited. 30a @120V isn't much...especially when the fridge kicks on.
Just because you don't have any 240V appliances running from the genny, doesn't necessarily mean you won't have some rewiring to do. The current set up is for 120/240.
Is that an auto or manual transfer switch?
Old 11-09-2013, 12:56 PM   #9
Manual xfer switc h
Old 11-09-2013, 11:16 PM   #10
If you are quite sure that there are NO 240v loads,
Then it's possible, but you will need a proper transfer switch,
I'am not sure whaat code allows for your area thou !
Best to consult an electrician, as this is NOT straight forward,
And must be done right to ensure maximum safety.
Old 11-10-2013, 06:52 AM   #11
What is wrong with the current transfer switch? I guess I really have 2 questions. How would i wire the 30A/120V generator into my current system. Would I be better off buying a new 30V/240A generator and would that work with my current setup, although i will still need a new 30 amp inlet box. The current cable running from the inlet box to the transfer switch is 10 gauge and about 25' long. Is that OK for 30Amps ?
Old 11-10-2013, 07:33 AM   #12
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
ok .. i am CORNfused ....
is see from the pictures
1 4 prong 30 amp installed ...
1 manual transfer switch
1 sub panel used as a "generator Panel"
all within about 6 feet of each other ??
where does the 30' of # 10 come into play .... the cord from the GEN ?? to the outlet/inlet ??
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 11-10-2013, 07:35 AM   #13
Rewards Points: 516
ok looked again .. so the outlet is 30' away from the transfer switch correct
Old 11-10-2013, 07:40 AM   #14
k_buz's Avatar
There is no issue with the transfer switch, there may have been if it had been a automatic one.
Old 11-10-2013, 05:36 PM   #15
Can the transfer switch be re configured to feed both legs from one 120v
source ?
Does code allow ?
