Generator Inlet - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-09-2012, 09:29 PM   #16
Missouri Bound's Avatar
Originally Posted by matt151617 View Post
Where does it say that? It's a regular generator. Quit crapping in my thread.
It's a friggin' joke....ease up. LIke your ideas so far.
Do you want it your way or the right way?
Old 10-09-2012, 11:51 PM   #17
Electrical Contractor
kbsparky's Avatar
I usually just mount the inlet in the side or bottom of the panel, and skip the junction box, etc.
-KB
Old 10-10-2012, 06:19 AM   #18
Rewards Points: 1,514
It often requires some force to unplug the (female) extension cord receptacle from the (male) inlet and a plastic blank cover in which you drilled a hole to mount the inlet is very likely to break. A metal cover should work okay.
If you don't have or wish to install a subpanel, a "small" single transfer switch won't work. A "whole house" transfer switch usually requires pulling the meter and thus some logistics coordination with the electric company. You can get a transfer switch box with several small transfer switches (for individual branch circuits) instead of one medium size transfer switch that you could install without disturbing the fat service wires.
Old 10-10-2012, 06:26 AM   #19
Rewards Points: 160
Thanks, I'll do that. $50 seems like a lot for just an inlet and a box, when the inlet itself is available for $20.
matt151617 is offline   Reply With Quote
Old 10-10-2012, 06:27 AM   #20
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Keep in mind everyone, this isn't your typical generator install...its 25A 120V only. There is no option for 240V.
