-   -   Generator Inlet (http://www.diychatroom.com/f18/generator-inlet-159572/)
matt151617 10-09-2012 07:08 PM
Generator Inlet
I'm hooking up a generator to my panel. The power cord is going to run through a small basement window and plug in next to the panel. All the power inlet boxes I've seen are designed for outdoor use and are therefore pretty expensive.
Can I buy one of these, http://i.ebayimg.com/t/Leviton-2615-...ICw~~60_35.JPG get a deep junction box with a blank cover, and drill with a hole saw the size of this outlet? Then connect to the panel with conduit and THWN wire?
Jim Port 10-09-2012 07:17 PM
You are going to need an approved transfer switch or interlock to prevent backfeeding on to the utility grid. You cannot just install the inlet.
matt151617 10-09-2012 07:25 PM
I am installing an interlock, I'm just looking for how to get the power in.
AandPDan 10-09-2012 07:30 PM
You need 4 pins, not 3.
matt151617 10-09-2012 07:31 PM
I know, that's just an example of the type of plug. I just want to know if I'm allowed to make my own inlet box.
AandPDan 10-09-2012 07:57 PM
Can you mount a 4 pin "inlet" on an approved box using an approved cover? Yes.
joecaption 10-09-2012 08:01 PM
When the power going to fail most likly? In the poring rain. Do you really want to have to leave a basement window open in a rain storm?
What about the CO2 coming in the window while it's running?
Missouri Bound 10-09-2012 08:15 PM
I'd urge you to consider a small transfer panel rather than an interlock. It's very often the same cost and unless you use a large generator you won't be able to power all of the circuits in your panel.
k_buz 10-09-2012 08:16 PM
You missed the part in his other thread where he posted the specs of his generator and it says that it is not to be used in the rain.
Missouri Bound 10-09-2012 08:19 PM
sheesh.....thought that was over.......:laughing:
matt151617 10-09-2012 08:35 PM
Where does it say that? It's a regular generator. Quit crapping in my thread.
Dan101 10-09-2012 08:43 PM
You will need an approved cover. Not a blank with a hole drilled in it.
Speedy Petey 10-09-2012 08:45 PM
A 30A gen inlet box is around $50. You consider that expensive?
joecaption 10-09-2012 08:50 PM
http://www.northerntool.com/shop/too...erator%2Binlet
k_buz 10-09-2012 08:55 PM
Do you think I just make this stuff up?
http://www.championpowerequipment.co...al-english.pdf
Page 3...Right-hand side
DO NOT touch bare wires or receptacles.
DO NOT use electrical cords that are worn, damaged
or frayed.
DO NOT operate generator in wet weather.
DO NOT allow children or unqualified persons to
operate or service the generator
Use a ground fault circuit interrupter (GFCI) in damp
areas and areas containing conductive material such
as metal decking.
Use approved transfer equipment to isolate generator
from your electric utility and Notify your utility
company before connecting your generator to your
power system.
Page 4...Bottom right-hand corner
Use the generator only for intended uses.
Operate only on level surfaces.
DO NOT expose generator to excessive moisture,
dust, or dirt.
DO NOT allow any material to block the cooling slots.
If connected devices overheat, turn them off and
disconnect them from the generator.
DO NOT use the generator if:
Electrical output is lost
Equipment sparks, smokes or emits flames
Equipment vibrates excessively
