Generator To Home Wiring... - Electrical - Page 4 - DIY Chatroom Home Improvement Forum
Old 08-30-2012, 12:12 PM   #46
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Im still confused why you hacked it in, just to unhack it, then do it properly?
Good luck though. Looks like a fun project.
Old 08-30-2012, 12:13 PM   #47
Originally Posted by stickboy1375 View Post
Why didnt you do it to begin with? That makes no sense...
Simply put, wasn't thinking about it at the time.
ngcreese is offline   Reply With Quote
Old 08-30-2012, 12:28 PM   #48
Thanks! Also, I appreciate you pointing this out. It's the reason I posted this project up in the first place. Before, working on this, I hadn't come across the topic of what you do with THWN/THHN wires inside a structure. I thought of switching back to NM-B once I entered the cabinet but thought it would be a good idea to keep a continuous flow of un-broken conductor as much as possible. Unless someone pointed it out and had a strong opinion, as you do/have.
Old 08-30-2012, 12:40 PM   #49
E2 Electrician
I personally would just buy a piece of carflex for the thhn, you can glue it right into the lb fitting and terminate it into the generator receptacle box, then run NM out of the that to the first GFI.
The Following User Says Thank You to stickboy1375 For This Useful Post:
ngcreese (08-30-2012)
Old 08-30-2012, 12:48 PM   #50
Ok, that sounds like a plan. I have more than enough spare 10/2 NM-B to run from the LB to the GFI and onto the secondary outlet. I'll have to grab the right carflex fittings, next trip to HD.
Old 08-30-2012, 01:19 PM   #51
E2 Electrician
you cant splice in the LB unless it is listed for it, so you would need a junction box, which isnt a bad way to go either...
New Home: 2 Prong Outlets & K&T Wiring (Maybe) weekley14 Electrical 4 05-29-2012 07:56 AM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 03:47 PM
fixing old wiring in 40's bulit home with rock lath pacifier1er Electrical 2 12-15-2009 06:31 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Home Wiring CAD Software fw2007 Electrical 4 02-11-2008 11:30 AM
