Originally Posted by jmjent51
“I have purchased the Power4Patriots System”. In it they describe the building of a DIY wind turbine. The project calls for an Ametek motor.
I'm not an electrician so I'm hoping someone here can simply tell me the correct Ametek motor and deep cycle batteries to get from Ebay. They have different ratings and all I want to do (at least in this project) is to use the wind turbine to power one 70 Watt high pressure sodium vapor dusk-to-dawn outdoor light.
Jim J.
In reality....you purchased a scam.
While on the surface, it looks great....there are a lot of 'little' details left out that in the long run will leave you in the dark.
Problem #1....the amount of air close to the ground is drastically lower than the wind up higher....one of the reasons you see comercial windmills so high in the air.
Problem #2.....any 'performance' claims are highly exagerated and very dependent on ideal conditions....
Problem #3.....any time a video uses 'patriotism' as a way to sell...is doing nothing more than scaming you.
If this was a truely viable idea....you would be seeing a lot more in the mainscream media.
Here is one link....
http://open4energy.com/forum/home-en...ts-scam-review
In case that is not enough....here is another link..
http://www.scambook.com/company/view...Power4Patriots
