Generator Connection - Electrical - DIY Chatroom Home Improvement Forum
Old 08-06-2009, 12:18 PM   #1
I want to install three dedicated electrical lines from my garage to power different appliances in case of outage. In the past I have run cords but hate the hassle and problems with closing my door. I would have three outlets that I could plug a male to male cord from the generator to the receptacle. Do I need a special receptacle like a 20 amp single or would a normal 15 amp duplex work? I wouldn't be running much more than 50 feet and using 12 gauge wire.
I know there may be better ways to power the house but I only really need my sump pump, refrigerator and a heater and lamp so a few receptacles around the house would work fine for me.
I appreciate any comments on this type of hookup.
CATZANDO is offline   Reply With Quote
Old 08-06-2009, 12:35 PM   #2
Rewards Points: 2,350
Dangerous. Deadly. Dumb. Illegal.
Old 08-06-2009, 03:11 PM   #3
dSilanskas's Avatar
Don't do it like that you can really hurt someone if not on your end if someone was working on a utility pole you could back feed and hurt them.
dSilanskas is offline   Reply With Quote
Old 08-06-2009, 03:15 PM   #4
Electrical Contractor
kbsparky's Avatar
NEVER use a "male to male" cord. The ends can be lethal.
-KB
Old 08-06-2009, 04:27 PM   #5
Let me clarify this since I seem have caused some confusion. This three receptacle system would be INDEPENDENT of my power system and therefore could not hurt a lineman since no juice could leave my home. I understand that a male to male connector is dangerous but is less dangerous when first plugged in a powerless receptacle prior to being plugged into the generator.
I'm sorry if this was unclear but my system is really little more than a fancier extension cord setup from the generator and I thought would also pose less of a tripping hazard.
Old 08-06-2009, 04:53 PM   #6
jbfan's Avatar
Rewards Points: 400
Still a dangerous and stupid thing to do!!!!!!!!
Old 08-06-2009, 05:08 PM   #7
Rewards Points: 266
At least use an "inlet" instead of a cord with two male ends.
junkcollector is offline   Reply With Quote
Old 08-06-2009, 05:08 PM   #8
Semi-Pro Electro-Geek
Rewards Points: 2,922
What would power those circuits while the utility is on? Sounds like those circuits would be generator-only then if you have no connection to your home wiring.
If you only want to run a few circuits from the generator, it's not that hard to do this the right way. You can get a 30A or so transfer switch, and wire your generator-powered circuits through a little subpanel off the transfer switch. It's easy, probably only costs an extra $100, and avoids the ridiculous use of double-male cords, which are like the physical manifestation of stupidity.
mpoulton is offline   Reply With Quote
