Generator Capacity - Electrical - DIY Chatroom Home Improvement Forum
Old 01-19-2012, 04:36 PM   #1
Generator capacity
will a generac 8000/12000 run a heat pump
pappyvic2 is offline   Reply With Quote
Old 01-19-2012, 04:37 PM   #2
Julius793's Avatar
How big a heat pump?
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-19-2012, 04:45 PM   #3
heat pump size
The heat pump is 13 seer and the air handler is 3 ton
Old 01-19-2012, 04:48 PM   #4
Julius793's Avatar
Wattage wise?
Old 01-19-2012, 04:58 PM   #5
Angry
generator capacity
i'm not sure i'll have to pull the paperwork and post when i have it. i apologize for not being prepared.
Old 01-19-2012, 05:22 PM   #6
Question
generator capacity
i didn't see any reference to watts. heat pump is 2.5 ton 13 seer it operates off a 30amp breaker in panel. the air handler is 3 ton
Old 01-19-2012, 05:24 PM   #7
Julius793's Avatar
Ok 30a is fine if thats the only thing your running. how about the air handler how much does it take?
Old 01-19-2012, 05:28 PM   #8
generator capacity
they both operate off that same 30amp breaker
Old 01-19-2012, 05:31 PM   #9
Julius793's Avatar
Oh then your fine, is that going to be the only thing on the generator?
Old 01-19-2012, 05:34 PM   #10
Question
generator capacity
no, the refrigerator and some lights and well pump that is on a separate 30amp breaker
Old 01-19-2012, 05:37 PM   #11
Julius793's Avatar
It won't be able to power it, you will need a bigger generator
Old 01-19-2012, 05:42 PM   #12
Question
generator capacity
can i run either the heat pump or the well with some lights and the refrigerator. i was planning on using a interlock switch on the main breaker box and only turn on the needed breakers.
Old 01-19-2012, 07:00 PM   #13
Rewards Points: 3,256
Of course you can.
zappa is offline   Reply With Quote
Old 01-19-2012, 09:06 PM   #14
NAIL BENDER's Avatar
Hey there Pappyvic2,
I recently purchased a Generac GP6500. This machine is rated at 6500 watts continues & 8000 watts surge. I tried to power a welder, which Miller powers with a 5500 watt continues generator, and my Generac wouldn't carry the load. I called Generac and they told me my engine is only 8.7 HP and Millers uses a Subaru engine with 14 HP. The conclusion I have drawn is; my Generac has more than enough electrical capability, but the engine doesn't have enough HP to power the generator. I have since noticed there are several other manufactures that offer engines with much more horse power than Generac on the same size machines. Dura-Max has one of this size with a 16 HP engine. If I were you I would research the horse power of prospective units more so than their wattage output.
Just my two cents, but I'll sell you this Generac I have for half what I paid for it and there is only about 2 or 3 hours on the engine clock.
Danny
NAIL BENDER is offline   Reply With Quote
Old 01-19-2012, 09:59 PM   #15
Semi-Pro Electro-Geek
Rewards Points: 2,852
It might be able to run both the well pump and the heat pump at the same time. A 30A breaker for a motor load probably indicates a continuous running current way lower than that. The heat pump may only draw 10A or so, and the well pump something similar. The only way to know is to try it and see if the generator will start both loads. You may find that one or the other needs to be started first.
mpoulton is offline   Reply With Quote
