Generator Cable Run - Electrical - DIY Chatroom Home Improvement Forum
Old 01-02-2012, 04:43 PM   #1
Rewards Points: 348
Generator Cable Run
Ran the cable for my generator today. I bought 25 feet of orange 10/3 cable. Well, it wasn't enough. I had about 20 more feet of 10/3 from a hot water installation ( white, type NM ).
I *CAN* splice this together right? If so, what size junction box do I need ( just two 10/3 cables with ground ). The splice will be about 10 feet from my main electric panel, so nice and dry and readily accessible.
I'm in NH If it makes any diff. I will call my building inspector tomorrow too to see if he has any issues with it.
dougp23 is offline   Reply With Quote
Old 01-02-2012, 04:50 PM   #2
Master Electrician
Rewards Points: 3,864
Do you have 10-3 with ground for both cables? Normally a water heater is connected with 10-2 with ground.
brric is offline   Reply With Quote
Old 01-02-2012, 05:18 PM   #3
Rewards Points: 348
Nope it's 10/3. I think the HW heater was 240v.
Old 01-02-2012, 05:20 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
And a water heater is usually wired with 10/2 since it is straight 240v.
Brric was just confirming.
You need a deep 4' sq box.
Old 01-02-2012, 05:25 PM   #5
Rewards Points: 348
Thanks brric and Speedy! I did not know that about a straight 240 needing just two conductors. How is it diff from a 240v dryer, which is usually 10/3? I am just curious, maybe the install I pulled the HW cable from was done wrong....
Old 01-02-2012, 05:30 PM   #6
biggles's Avatar
might consider a fused disconnet so you get the connection... the weather tight box...and fusing all in one or just copper bug the lines rubberized tape and electrical even those plastic clam shells to seal each wire....
Old 01-02-2012, 06:31 PM   #7
Mad Scientist
Straight 240 does not need a neutral, so 10/3 is fine, but wasteful since a wire is left unused.
An electric dryer, or (usually) an electric stove, are actually 120/240. The heating elements work at 240V, but the timer, motor, and other controls use 120V. Thus, those appliances require the neutral to get 120V.
McSteve is offline   Reply With Quote
