Generator Bonded Neutral And Ground - Electrical - DIY Chatroom Home Improvement Forum
Old 10-05-2011, 08:44 PM   #1
generator bonded neutral and ground
I have a Mitsubishi 6000 watt generator which has a bonded neutral. I have a complete off grid solar system with a main panel that has bonded neutral and grounds. My generator had a problem last night and I'm thinking that since it acts as a main panel, it is reading my main as a sub-panel which wouldn't or shouldn't be bonded. I think I need to rewire the generator to have a floating neutral. Anyone know how to do this? Thanks for any help!
mreed is offline   Reply With Quote
Old 10-05-2011, 08:47 PM   #2
Rewards Points: 1,534
What are the symptoms that suggest to you there is a problem?
One lesser-of-evils is to connect the generator to the home system with the green wire unhooked.
A generator should not be connected to the system at the same time the solar panels are connected unless there is circuitry specifically to allow them to coexist. You can use a standard transfer switch to select either solar or generator power.
AllanJ is online now   Reply With Quote
Old 10-05-2011, 10:54 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,970
Your previous thread involving your solar power system made no mention at all of a generator. That changes the whole situation; we needed to know that before. This generator is probably 240V, and your panel is wired for 120V only with both busses jumpered together at the inverter's breaker. How do you have the generator connected?
Again, pictures would be REALLY useful.
mpoulton is online now   Reply With Quote
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-22-2010 11:40 PM
sub panel ground and neutral daddyrabbit Electrical 3 01-29-2010 06:49 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
