Generator Backfeeding Incidents - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-17-2013, 09:16 AM   #16
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
http://www.powerequipmentdirect.com/...189de-64893573
The Following User Says Thank You to stickboy1375 For This Useful Post:
Kyle_in_rure (08-17-2013)
Old 08-18-2013, 02:04 AM   #17
" Euro " electrician
frenchelectrican's Avatar
Even over here in European area we do have issue with backfeeded generatours as well. they are no differnt than Americians do with their backfeeded set up.
I have see few small portable generatours blow up from illegal backfeed when the uility system got the power back on.
The lineperson over here in France the EDF ( French POCO ) have one common rules treat them as alive and ground them out ( on primay line )
And I have done quite few repairs from backfeeded generatours and the generatour itself is toasted as useal which I do expect that ( few case the stator will rip apart )
For backfeeded larger unit genrally it will be 50-50 split useally either breaker will trip or stall or damage the generatour or even worst is destory the prime mover aka engine and I have see some funky mess with it.
So., Basically never ever I say never backfeed in the building system at all unless you have proper transfer switch., end of that conneries.
Merci,
Marc
The Following 3 Users Say Thank You to frenchelectrican For This Useful Post:
Kyle_in_rure (08-18-2013), Philly Master (08-18-2013), raylo32 (08-18-2013)
