Generator Back-feed Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 10-22-2012, 11:59 AM   #1
Joe F's Avatar
Rewards Points: 294
Generator back-feed wire
I'm planning to set up a back-feed to my panel from my 4400w portable generator via the twist lock connector. I have an unused 12/3 run from the spot that I'd like to use to position the generator. Is 12/3 large enough to support this usage?
FYI - it will go to an interlocked breaker in the main panel.
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 10-22-2012, 12:07 PM   #2
Julius793's Avatar
Should be fine, what kind of wire?
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 10-22-2012, 12:12 PM   #3
4400 watts at 240 volts pulls 18 amps. 12 guage wire is usually good for 20 amps.
Auger01 is offline   Reply With Quote
Old 10-22-2012, 12:13 PM   #4
Joe F's Avatar
Rewards Points: 294
It's direct bury cable. If I remember correctly, it's in conduit. It runs from a sub-panel in my detached garage, back to the main panel in the house.
When I add the interlocked breaker in the main panel, I assume I should use a 40 amp two pole, correct?
Old 10-22-2012, 12:48 PM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,922
A 20A breaker is adequate.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 10-22-2012, 01:33 PM   #6
Rewards Points: 806
If you are feeding into a sub panel in garage and have the interlock breaker in another panel (the main home panel) how will the interlock work? Aren't they usually a mechanical bar that forces you to shut off the main feeder breaker prior to engaging the feeder break from the generator? It seems your scheme could allow for the possibility of having the generator still feeding while switching back to PoCo power. Smoke to follow shortly after the arcing and banging noises..
curiousB is offline   Reply With Quote
Old 10-22-2012, 02:06 PM   #7
Joe F's Avatar
Rewards Points: 294
I hate to say it, but I didn't consider a scenario where someone would energize the circuit at the sub-panel prior to configuring the main panel. I'll just wire straight through and not tie in through the sub-panel. Thanks!
wiring a whirlpool cooktop davidtyson Electrical 8 06-17-2012 01:58 AM
Ceiling fan and wire gauge needs? greentrees Electrical 6 05-01-2012 01:05 AM
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 02:06 AM
HVAC three wire motor to six wire motor Leo Caproni HVAC 5 10-18-2010 01:23 PM
