Generator Back Feed Breaker In A Homeline Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 01-19-2011, 03:03 AM   #1
Generator back feed breaker in a homeline sub panel
I'm interested in getting a sub panel set up to transfer from the main(s) supply to a generator back feed breaker. I'd want a 100amp or 125 amp sub panel and I want to service a number of selected circuits (one at 240V; the others at 120V) from the panel. I expect to wire this panel to my generator and have it ready to service the selected circuits when I lose power from the mains.
Ward Carson is offline   Reply With Quote
Old 01-19-2011, 03:25 AM   #2
Electrical Contractor
kbsparky's Avatar
Great! What's your question(s)?
-KB
Old 01-19-2011, 09:13 AM   #3
Rewards Points: 1,418
Wiring up a generator is more straightforward when the portion of the circuits to be generator powered are all in a subpanel.
You will have a breaker pair in the main panel to forward-feed the subpanel.
Run the cable from this breaker pair to one leg of the transfer switch. Run the generator feed to the other leg. Run the subpanel feed cable (also forward fed to top of subpanel) to the transfer switch common.
This transfer swittch should have three poles so the neutral between the main panel and the subpanel is switched along with the hots.
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 08:15 PM
breaker panel Ehren51 Electrical 3 01-20-2015 06:23 PM
Old House Rewire finnimus Electrical 15 05-13-2011 11:39 PM
Distance between the main breaker panel and a manual transfer switch panel jerryallie Electrical 2 09-01-2010 09:11 PM
Bad breaker panel??? drjay9051 Electrical 9 08-25-2010 04:43 PM
