Generator AC Unit - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-22-2012, 08:52 PM   #31
is there any way i can make my own hard start kit for a 1,5 ton ac ?
quanchai is offline   Reply With Quote
Old 07-23-2012, 06:50 AM   #32
Rewards Points: 756
Originally Posted by quanchai View Post
Magnetic relays it's made to transfer the power betwin 3 power sources, It does around 20 transfers a day has been working for 2 years now without a single problem
I can take a picture of it an show you ?
If by magnetic relays, you mean contactors, you could have a problem down the road. Contactors work fine for many cycles, but one of their failure modes is welding the contacts closed. This is caused by the repeated arcing at the contacts destroying the silver plating on the contacts. If contacts fail closed, you may get some spectacular or even dangerous/deadly results.
For the record, some cheaply made commercial transfer switches use contactors, but they are for optional generators and probably only switch a few hundred cycles in their entire useful life.
Mark
busman is offline   Reply With Quote
Old 07-23-2012, 07:33 AM   #33
You are right but the type i have been using for the last two years works perfect with around 60 amps load at all time
Old 07-24-2012, 02:12 PM   #34
It's right censored data; you'd know more about its reliability if it failed once in a while.
Just make sure the contacts are rated for a motor load and that you fuse the lines in the event the relay fails.
Old 07-24-2012, 04:21 PM   #35
Can you recommend some thing better like how about solid state relays ?
Old 07-26-2012, 12:01 PM   #36
I'd stay with electromechanical but there is a way to monitor the life of your relay contacts.
At rated current, good contacts measure less than 30 mV and bad contacts come in at more than 100 mV. Possibly if you're running at half rated current, the values would be 15 mV and 50 mV.
Had a HO with flaky HVAC blower performance and it was working when I was there but the relay contacts came in right at 100 mV.
Took a chance, replaced the relay, everybody lived happily ever after.
Old 07-26-2012, 03:45 PM   #37
But is sold relays not better
They dont have any moving parts
Old 07-26-2012, 03:47 PM   #38
Sold State relays does also com in 100 amps
Old 07-26-2012, 03:54 PM   #39
Dunno'.
Compare cost vs. MTBF for both types. And for EM relays sometimes you can replace only the contacts in the case of failure.
Old 07-26-2012, 04:01 PM   #40
i think using a timer with the contactor would be better because there would not be any instant switching
Old 07-26-2012, 07:51 PM   #41
Could you please explain more about how to moitor the life of the relay ?
Old 07-27-2012, 08:43 AM   #42
Find a tech library and get books on electrical testing.
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 10:11 AM
Had an Aire-Flo AC installed, looking for opinions mikemcd HVAC 14 08-01-2011 04:07 AM
new r-410a ac unit installation procedure(w/old unit r-22)? excalibur1 HVAC 0 06-06-2011 03:47 PM
Window A/C Unit and Supplying Power JayEnder Electrical 1 04-30-2011 07:50 PM
Inside Unit Runs, Outside Unit Runs (with help) no cold air beakon20 HVAC 4 08-13-2008 09:33 PM
