Generator AC Unit - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-22-2012, 01:50 PM   #16
If I read correctly, your setup has been working for two years but suddenly stopped working, is that correct?
This may help:
http://www.five-two-one.com/index.htm
Auger01 is offline   Reply With Quote
Old 07-22-2012, 01:51 PM   #17
Originally Posted by quanchai View Post
Magnetic relays it's made to transfer the power betwin 3 power sources, It does around 20 transfers a day has been working for 2 years now without a single problem
I can take a picture of it an show you ?
By all means, please do.
Old 07-22-2012, 02:44 PM   #18
no the ac units has just been installed
quanchai is offline   Reply With Quote
Old 07-22-2012, 03:15 PM   #19
is it possible to install another capicitor to the ac?
Old 07-22-2012, 05:24 PM   #20
so is there any way to reduce the surge ?
Hard start kit, but now I'm thinking one or more of your ACs are failing and drawing excessive current.
And you may also have wiring problems in your house.
You need to monitor what's going on at the moment when the gen cuts out, where that current is going and why.
Old 07-22-2012, 05:56 PM   #21
Wiring is ok the problem is the ac unit
Can i use a normal capacitor as a hard starter i mean hooking up another capacitor beside the old one ?
Old 07-22-2012, 06:02 PM   #22
regarding the relay here is a picture of it
it can handle 120 amps
This is the 80 amps version i run the 120 amps version AC
I got two of those hooked up with some timers and voltage sensing relays like i said has been working perfect for 2 years now!
Old 07-22-2012, 06:09 PM   #23
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Can you take a picture of your setup?
Old 07-22-2012, 06:54 PM   #24
um... NO. Cobbing up your own hard start kit is not that difficult, if you know what you are doing. If you screw it up, you probably will destroy your compressor. Is that 40$ kit starting to look better now?
Old 07-22-2012, 07:36 PM   #25
Sure but the advanced version that i have built with the timers and voltage sensing relays is not in the place where i am now i will take a picture of the basic one that is built to switch betwin 3 power sources and handles 60 amps and can handle max 120 amps
Old 07-22-2012, 07:37 PM   #26
The problem is that i cant find the hard start kit here in sweden
Old 07-22-2012, 08:02 PM   #27
there you go
Old 07-22-2012, 08:34 PM   #28
Master Electrician
Those dont look like #6 wires to me. Or am I way off base.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-22-2012, 08:44 PM   #29
E2 Electrician
You have the internet at your fingertips...
Old 07-22-2012, 08:49 PM   #30
It's #6 wires
this box i messy and i dont like the look of it the one that i have back in my other place is a bit larger and handles
4 power srouces and has timers and voltage relays for protection. It has been running for 7 months stable
I am planning to build one that is controled by a PLC and uses solid state relays
they are far much better even thoughi havent had any problem with the mechanical ones
but the problem is that i am not that good with plc programming if somone here is good with plc's and is willing to help to build this new ATS feel free to PM me
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 10:11 AM
Had an Aire-Flo AC installed, looking for opinions mikemcd HVAC 14 08-01-2011 04:07 AM
new r-410a ac unit installation procedure(w/old unit r-22)? excalibur1 HVAC 0 06-06-2011 03:47 PM
Window A/C Unit and Supplying Power JayEnder Electrical 1 04-30-2011 07:50 PM
Inside Unit Runs, Outside Unit Runs (with help) no cold air beakon20 HVAC 4 08-13-2008 09:33 PM
