Generator - Electrical - DIY Chatroom Home Improvement Forum
Old 05-27-2014, 06:41 PM   #1
generator
Hello I had to move my whole house generator 4 foot from my house and the whip does not reach,can I make one to reach or do I have to run conduit under ground, is there a certain length your allowed by code thanks john
weldnut is offline   Reply With Quote
Old 05-27-2014, 07:31 PM   #2
Rewards Points: 6,652
It all depends on what your local code office states. If you are moving it because of noise. Take into consideration the tripping hazard if you do not bury conduit for the wiring between the genset to the Interlock panel or Disconnect on the side of the house.
Old 05-27-2014, 08:04 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Really? A state is going to file an amendment on distance of a generator?
The Following User Says Thank You to stickboy1375 For This Useful Post:
electures (06-03-2014)
Old 05-27-2014, 08:05 PM   #4
E2 Electrician
You can either purchase a longer whip or make your own, in my opinion, its cheaper to purchase a longer whip.
Old 05-30-2014, 03:11 PM   #5
generator
THANKS everybody for your help
Old 06-03-2014, 11:18 AM   #6
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
6' ............
230.43
(15) Flexible metal conduit not over 1.8 m (6 ft) long or liquidtight flexible metal conduit not over 1.8 m (6 ft) long between raceways, or between raceway and service equipment, with equipment bonding jumper routed with the flexible metal conduit or the liquidtight flexible metal conduit according to the provisions of 250.102(A), (B), (C), and (E)
(16) Liquidtight flexible nonmetallic conduit
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 06-03-2014, 05:19 PM   #7
E2 Electrician
Originally Posted by philly master View Post
6' ............
230.43
(15) flexible metal conduit not over 1.8 m (6 ft) long or liquidtight flexible metal conduit not over 1.8 m (6 ft) long between raceways, or between raceway and service equipment, with equipment bonding jumper routed with the flexible metal conduit or the liquidtight flexible metal conduit according to the provisions of 250.102(a), (b), (c), and (e)
(16) liquidtight flexible nonmetallic conduit
what??????
Old 06-03-2014, 07:10 PM   #8
Rewards Points: 1,192
You can bury liquidtite.
bobelectric is offline   Reply With Quote
Generator & Interlock Kit Float the Neutral? Arnold Ziffel Electrical 12 01-13-2013 06:28 PM
Generator connection Question - Final Plan Apollo67 Electrical 24 01-30-2012 08:44 PM
B&S Generator with Connecticut Electric Xfer Switch Rick5150 Electrical 19 01-20-2011 11:14 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 12:59 PM
