Generator 15KW - Electrical - DIY Chatroom Home Improvement Forum
Old 07-23-2010, 04:01 PM   #1
jburd964's Avatar
Rewards Points: 166
Generator 15KW
Getting ready for hurricane season and purchased a 15kw pto generator. It came with a 8' plug and play power cord. I'm considering a way to remove tractor and noise away from house. The closest cover shed is 150' to 200' away. What size wire would be required to make that long of a run and not loose voltage.
jburd964 is offline   Reply With Quote
Old 07-23-2010, 04:22 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
depends on what the load was at any given time. Voltage drop is calculated by using resistance, supply voltage, and current.
Old 07-23-2010, 04:39 PM   #3
Rewards Points: 502
any run of any wire will lose some voltage.
1/0 Al was what I was told to get for a 150' run to a 100 amp sub.
that should be about the same neiborhood for your purposes.
If you do this, I'd burry the wire so it stays safe.
depending on how the suply is running to the house, there is a chance you could tie in to the suply line. probably not, but I could at this house. There is a disconect at the last pole, just before the meter, before a 300' burried run
forresth is offline   Reply With Quote
Old 07-23-2010, 09:58 PM   #4
jburd964's Avatar
Rewards Points: 166
I thought it would around 1 r 2 alt would rather have some fat built in and plan on burying it in conduit.
Old 07-24-2010, 02:16 AM   #5
" Euro " electrician
frenchelectrican's Avatar
With 200 feet distance with 15 KW @ 240 volts you will need 25mm˛ {#4 AWG } copper or larger.
And for conduit you will need 1.5 inches with that distance { and use plenty wirelube to help pull along the way }
There will have more addtional local codes it may come up so check it out to see what they required and of course you will need a transfer switch.
Merci.
Marc
Old 07-24-2010, 08:01 AM   #6
jburd964's Avatar
Rewards Points: 166
I just built new house and brought the power in underground, code required that it be buried in conduit 3 ft deep.
