Generator - Electrical - DIY Chatroom Home Improvement Forum
Old 06-30-2011, 02:26 PM   #1
generator
How do I know how many appliances can be powered by a 8000 watt generator? Nothing came with the owners manual. Is there a site that contains a list? Can you power a well pump with the generator
Lois Nicely is offline   Reply With Quote
Old 06-30-2011, 03:16 PM   #2
delawareIT's Avatar
8000 watts is a pretty healthy source of power..
you should have no problem with fridge, tv and a small AC window unit..
delawareIT is offline   Reply With Quote
Old 06-30-2011, 03:55 PM   #3
the Musigician
DangerMouse's Avatar
About 6,000 watts constant. Yes, it will run a well pump easily.
DM
Old 06-30-2011, 04:27 PM   #4
DIY staff
Rewards Points: 7,174
Your well pump may be 220 volt---be sure the generator has a 220 outlet.
Old 07-01-2011, 01:53 AM   #5
" Euro " electrician
frenchelectrican's Avatar
for 8,000 watt generator there is two diffrent wattage it will read either it will read Surge { maxuim } wattage or contsant watt or rated wattage which that mean the generator can go up to the X numbers of watts before it get overloaded.
However with 8KW { Kilowatts } unit it will handle pretty good amount of load without issue beside few very large motour load { typically A/C unit is a iffy depending on surge rating }
But for common household appalinces that is a brezze however make sure you have proper transfer switch and also want to give you a head up make sure you balance the load this is more noticeable on generator power mode than normal uility power mode.
As far for the well pump motour in most case it will handle up to 3/4 HP without too much issue as long you don't have much load on the generator but when you get full load then you will run into it{ may can trip the generator breaker if overloaded some case it may stall the engine }
Most of resdentail well pump what I heard and see useally half horsepower is the most common one but there are few case 3/4 is pretty common but not on the farm they will go more than a horsepower or larger.
Merci,
Marc
Old 07-01-2011, 10:54 AM   #6
Rewards Points: 150
Use this chart to calculate what you can run, like DM said you probably have about 6000 continuous running watts available so all you have to do is add up the wattages of the appliances you want to run and you are good to go if it is under 6000 watts.
http://alternative-heating-info.com/...age_chart.html
josall is offline   Reply With Quote
Old 07-01-2011, 06:35 PM   #7
dmxtothemax's Avatar
Rewards Points: 5,096
Most appliances should have there power usage marked on them,
There is usaully a plate or sticker some where,
But 8000w is usually plenty,
Even the pump should be quite happy.
dmxtothemax is offline   Reply With Quote
B&S Generator with Connecticut Electric Xfer Switch Rick5150 Electrical 19 01-20-2011 11:14 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 12:59 PM
Well Pump to Generator Question Sprice Electrical 1 02-11-2009 12:27 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
Feeding multiple subpanels with a single generator monsoon Electrical 8 10-02-2007 05:25 PM
