Generally, How Far Can You Go Prior To First Inspection? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-22-2010, 07:46 PM   #1
Generally, how far can you go prior to first inspection?
Wiring attached garage as soon as builder has it ready. Pulled permit and have spoken a few times to the inspector. He'll be out twice, once before drywall goes up and than again afterward. He commented that I could go ahead and wire up a light right away to assist my work. Since he knows there will be a sub panel for all circuits, assume that's acceptable as well. Regarding the remaining work, are you generally expected to wire everything completely prior to first inspection and just leave breakers switched off? Obviously, would like to go as far as is reasonable, without running afoul of the inspector. Your experiences appreciated. Thanks.
Mi Feller is offline   Reply With Quote
Old 05-22-2010, 07:56 PM   #2
joed's Avatar
Rewards Points: 12,854
Rough inspection generally is all the cable pulled into the boxes, grounds made up, no devices or connections to breakers.
After rough inspection, drywall goes up and devices are installed to a finish state. Then final inspection and approval.
The Following User Says Thank You to joed For This Useful Post:
Mi Feller (05-22-2010)
Old 05-22-2010, 08:41 PM   #3
Registered User
Termite's Avatar
This inspector fully agrees with JoeD's post!
Never hurts to call your inspector to determine his expectations though.
The Following User Says Thank You to Termite For This Useful Post:
Old 05-23-2010, 08:19 AM   #4
Licensed electrician
Rewards Points: 1,610
Joe summed up things very well.
If you were to install the switches and receptacles they will get in the way of the drywallers and end up behind the drywall.
Old 05-23-2010, 07:19 PM   #5
Would be hard accessing them behind the drywall! Thanks
what to do for plumbing rough inspection? red86yota Plumbing 5 09-12-2010 04:39 PM
Passed my rough inspection, now what? theatretch85 Electrical 12 05-03-2009 02:11 AM
Home Inspectors / Non Disclosed Issues PreSale AndrewF Off Topic 14 02-06-2009 10:18 PM
Ontario Inspection finishing basement dave1699 Electrical 4 12-01-2008 08:09 AM
State Vehicle Inspection - ARGGH Leah Frances Off Topic 14 04-05-2008 12:59 PM
