Old 04-08-2006, 08:10 AM   #1
Tim
Unhappy
General Wall Swith Question
Hi,
I'm changing out my old wall switches to new decorator type.The problem I have is,I cannot get the speed wire holes to release the wires.I did as instructed,by using a screwdriver to push in the release.I did this with 2 of the old swithes but no luck.Is there a trick to getting the wires to release?? Thanks Tim...
Tim is offline   Reply With Quote
Old 04-08-2006, 08:24 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Yes, sometimes you have to "angle" the tool or move it around to get tham to release. It's rarely as simple as pushing the tool in and the wire popping out.
Old 04-08-2006, 12:06 PM   #3
Electrician
If you are trying to get them out of the old one and have enough wire save your self the frustation and cut the old wires close to the switch and restrip them.
Darren
darren is offline   Reply With Quote
Old 04-12-2006, 08:43 AM   #4
Extreme DIY'r Adk's, NY
I had the same scenario trying to put a dimmer in a previous house. The wires were very short and stapled to the stud so I could cut them. With the power off of course, I successfully smashed the old switch to bits with some grunting and a pair of 12" channel lock pliers. Then you can "manually" release the wire and there's no plastic in the way for "angling."
good luck
crecore is offline   Reply With Quote
Old 04-12-2006, 01:36 PM   #5
Doing it myself
Alan's Avatar
This is why I NEVER use the speedholes. :D
Its worth the extra 20 seconds it takes to bend the wires around the posts in case i have to take the switch back out later.
knee wall question jscholl411 Building & Construction 7 10-10-2007 01:30 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Floor and wall tile question irlizard Flooring 21 07-20-2006 02:35 PM
One more wall question J187 Building & Construction 7 05-25-2006 06:57 PM
