General Service Panel Question About Ground / Neutral - Electrical - DIY Chatroom Home Improvement Forum
Old 03-17-2010, 08:16 AM   #1
Rewards Points: 640
general service panel question about ground / neutral
After seeing panels wired many different ways... was wondering about one thing... most panels I see have two sets of screw terminal bars... one on the left and on on the right of the main hot bus... a lot of wiring books have each side dedicated to wiring ground on one side and neutral on the other... but in production, I see ground and neutral intermixed... any real difference about this? besides just being neat and tidy with all the same color on the same side?
BlueBSH is offline   Reply With Quote
Old 03-17-2010, 08:26 AM   #2
Just call me Andrew
Rewards Points: 1,020
In a main panel, the neutral bar and ground bars are essentially the same. They are connected. (This is NOT true for a subpanel.) I think the only reason to keep grounds & neutrals on their own bars in a main panel is for organizational purposes.
In my small 100-amp main panel (small '50s house) there is only one ground/neutral bar and both whites & bare wires are connected to it. This passed an electrical inspection, by the way.
Andrew
secutanudu is offline   Reply With Quote
Old 03-17-2010, 08:30 AM   #3
Master Electrician
Rewards Points: 3,772
No real issue although grounded conductors(whites) are to be landed individually(no doubling) to be code compliant.
brric is online now   Reply With Quote
Old 03-17-2010, 07:55 PM   #4
No problem with them being mixed. Although if you were to subfeed a smaller panel from your main code requires you remove the bar connecting the two..
NSimon is offline   Reply With Quote
Tags
grounding
Sub Panel install eagertolearn Electrical 17 01-23-2010 06:39 PM
Hot and Neutral at Service Panel Bocolo Electrical 10 03-09-2009 10:23 PM
GFCI feeing subpanel question scott2332 Electrical 45 02-28-2009 04:15 PM
Electrical connections TazinCR Electrical 11 01-07-2009 08:10 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 11:31 AM
