Old 09-01-2012, 09:55 AM   #1
General purpose conduit to detached garage
I have a detached garage which is about 12 ft from the house and which has a separate workshop area. Expected load is portable tools and supply to recharge the plugin hybrid. I will also be supplying the main house when power goes out (from car), when there is excess photovoltaic power (to be installed) and/or when a separate static battery bank is installed and were off grid.
I was thinking of burying 3" PVC to house electrical and future water lines for carrying heated water (solar thermal). Should these conduits be separate or can I nest one inside the other? Should I use 12-2 wire or THHN/ THWN and with what housing? Also, I cannot dig to 12" unless I go below the footer (see pic).
Need advice.
kurtp2 is offline   Reply With Quote
Old 09-01-2012, 11:20 AM   #2
Missouri Bound's Avatar
You will need seperate conduits for each applicatoin...low voltage, heating tubing, and line voltage. If you are intending to use more than one circuit in the garage you will need a sub-panel.
Do you want it your way or the right way?
Old 09-01-2012, 11:28 AM   #3
Lic Electrical Inspector
electures's Avatar
Need advice.
Attachment 56686
Romex cannot be installed in a wet location.
All responses based on the 2011 NEC.
If you live in New Jersey click
. All other states click
Please check with local, county and state officials as laws may vary.
Sizing motors
. Online motor calculator
. Online calculators
electures is offline   Reply With Quote
In theory: expand attached garage, or add detached garage? hyunelan2 Building & Construction 5 11-09-2012 06:34 PM
Underground power run to detached garage has failed-what to do now? BT5150 Electrical 8 06-26-2012 09:15 PM
Pulling large gauge wires through conduit bodies and conduit around garage door. rrolleston Electrical 65 02-07-2012 04:11 PM
House and detached garage need new roofs looking for tips and advice jimtmcdaniels Roofing 3 11-06-2009 10:07 AM
ENT (Smurf) feeding a sub in detached garage) jamiedolan Electrical 1 02-02-2009 01:52 PM
