-   -   General purpose conduit to detached garage (http://www.diychatroom.com/f18/general-purpose-conduit-detached-garage-155464/)
kurtp2 09-01-2012 09:55 AM
1 Attachment(s)
I have a detached garage which is about 12 ft from the house and which has a separate workshop area. Expected load is portable tools and supply to recharge the plugin hybrid. I will also be supplying the main house when power goes out (from car), when there is excess photovoltaic power (to be installed) and/or when a separate static battery bank is installed and were off grid.
I was thinking of burying 3" PVC to house electrical and future water lines for carrying heated water (solar thermal). Should these conduits be separate or can I nest one inside the other? Should I use 12-2 wire or THHN/ THWN and with what housing? Also, I cannot dig to 12" unless I go below the footer (see pic).
Need advice.
Attachment 56686
Missouri Bound 09-01-2012 11:20 AM
You will need seperate conduits for each applicatoin...low voltage, heating tubing, and line voltage. If you are intending to use more than one circuit in the garage you will need a sub-panel.
electures 09-01-2012 11:28 AM
Need advice.
Attachment 56686
Romex cannot be installed in a wet location.
