General Circuit And Amps - Electrical - DIY Chatroom Home Improvement Forum
Old 11-20-2011, 07:02 AM   #1
General circuit and amps
Hey:
I have two questions. We have a 15 amp general circuit in the cellar that I wanted to add a small (.9 amp) freezer to. There are 10 < 60 watt lights and a small refrigerator on the circuit.
1.) Any guess on the amperage for an old, 12.2 cu ft Admiral fridge? Can't find it listed anywhere.
2.) What amperage can I go up to on a 15 amp general circuit? I get confused which are for 50%, 80% and 100% of rating.
Thank you.
whatrymes is offline   Reply With Quote
Old 11-20-2011, 07:30 AM   #2
Rewards Points: 6,652
Run a new circuit for the freezer. Keep the lighting on its own circuit. And, you will be fine with a 15 amp for the freezer, but personally, I would make it a 20 amp circuit with 12/2 romex ran, if your area allows for romex to be used.
Old 11-20-2011, 07:38 AM   #3
Licensed electrician
Rewards Points: 1,610
Look or or near the door for the nameplate data on the old refrigerator. I suspect around 12 amps or so.
I would run a new circuit for the old refrigerator if the freezer is only an amp.
Old 11-20-2011, 07:45 AM   #4
For a 0.9 amp freezer??
Old 11-20-2011, 07:46 AM   #5
I looked all over the fridge, can't find the plate??
Old 11-20-2011, 07:53 AM   #6
You may need to look near the grill near the floor. It may be behind it.
Old 11-20-2011, 12:51 PM   #7
If the space is unfinished, you need to use a gfci protected outlet. That means I would stay off of the lighting, due to you do not want the fridge tripping the lighting circuit, even if it was not gfci protected. It is just common sense. Also, the reason for the dedicated circuit, is that it is there to allow you to use for other stuff, not just the freezer (ie shop vac, tools, vacuum, etc.)
I ran a dedicated 15 amp for our bar fridge and upright freezer, because as I stated before, it just made better sense to do so, than run off of a lighting circuit, which you want to do.
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 06:09 AM
how to figure amps on a circuit? bcbud3 Electrical 5 01-22-2010 12:11 PM
Change circuit breaker amps for downgrade? katzdad HVAC 2 11-05-2009 04:37 AM
What is the meaning of KA(kilo amps) of a miniature circuit breaker? wkyong Electrical 2 09-12-2008 12:39 AM
Max amps allowed - electrician advice needed Des Electrical 27 06-05-2008 10:31 PM
