General Breaker Question - Electrical - DIY Chatroom Home Improvement Forum
Old 10-18-2010, 04:53 AM   #1
General Breaker question
A friend of mine has a breaker that keeps tripping after putting a pretty small load on it (several lights, an outlet with a portable heater, and the microwave). Now, I haven't actually looked at anything yet, but I'm curious, what is the tell tale sign of a bad breaker, and what way can I be sure it's the breaker.
I haven't done a lot of home electrical, but I do have a background in some low level electrical (I used to repair arcade game and I did some commercial lighting work), so I'm not going in this blind or anything. I'm just curious as to how to attack this thing.
Fix
fixittech is offline   Reply With Quote
Old 10-18-2010, 06:51 AM   #2
Electrical Contractor
kbsparky's Avatar
An outlet with a portable heater and a microwave is not a "small load"
Sounds like an overloaded circuit to me.
-KB
Old 10-18-2010, 07:07 AM   #3
Rewards Points: 1,214
Thank GOD the breaker is doing what it supposed to do.
COLDIRON is offline   Reply With Quote
Old 10-18-2010, 07:45 AM   #4
jbfan's Avatar
Rewards Points: 138
Not a small load at all!
Move the heater someplace else.
Give up trying to troubleshoot someone else's problem if not quailified!
Old 10-18-2010, 08:58 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Agreed with other posters- overload!
Heater 1500 watts, microwave 1000 watts, a few lights 300 watts
2800 watts @ 120 volts = about 23 amps.
Coastal South Carolina
Old 10-18-2010, 01:06 PM   #6
Thanks guys, I figured as much. I just look at my dad with his 2 power strips in the same outlet with 15 different things in it and wonder he doesn't have the same problem. ;-)
Just another question (and no, I'm not trying to troubleshoot, I'm just curious as to how this works), How likely is it that the same breaker is handling things on two different floors, on opposite walls? Microwave is upstairs in the kitchen, lights are on downstairs and the outlet that this little heater is using is on the wall opposite of the kitchen. It would make more sense to me if it were all wired on the same wall. Now this house is maybe 30 years old, but what would be the reason for such wiring?
Old 10-18-2010, 01:12 PM   #7
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
=fixittech;518861]Thanks guys, I figured as much. I just look at my dad with his 2 power strips in the same outlet with 15 different things in it and wonder he doesn't have the same problem. ;-)
either he has a lot of smaller loads that do not add up to some amount that would overload the circuit or the various loads are not all drawing power at the same time.
In your situation, if you run only the microwave or only the heater, probably even with the lights in either case, you will not trip the breaker.
because that is how somebody wired it.
My guess is that somebody added onto an existing circuit without any regard to what that circuit was already feeding.
Old 10-18-2010, 03:16 PM   #8
Reminds me of when I lived in an apartment and I had a saltwater reef tank. I had two power strips plugged into a wall outlet and every plug on the power strip was being used by the lights, pumps, power heads, and heaters. We got a notice that the fire inspector was going to be going through all of the apartments to look for unsafe conditions. I meticulously looked up the current draw from each device that was plugged in and added them up and pasted it on the fish tank for the inspector to see. 12 items plugged in but still only added up to about 3 amps.
jerseyguy1996 is offline   Reply With Quote
panel breaker question officersdr Electrical 1 09-18-2010 05:22 PM
wiring new GFCI breaker question dgates12 Electrical 8 01-07-2010 01:14 PM
AFCI breaker question Sheryl Martin Electrical 4 07-06-2009 03:10 PM
Question on 240v double pole breaker locations rovers1973 Electrical 10 02-14-2009 06:15 AM
