Old 11-08-2011, 04:11 PM   #1
Generac Transfer Switch Wiring
Installing a Generac 17kw with EZ Switch. The wire that came with the switch is about 12 short - panel is on opposite side of house from switch. It came with #6 wire and I'm thinking of swapping it out and using #4 wire from the panel to the switch. OR, could I splice the #6 wire into a box and run #6 the extra 12' length to the switch? Thanks.
diesel_farmer is offline   Reply With Quote
Old 12-13-2011, 08:31 PM   #2
VA master electrician
Is it the 100A subpanel with the 30' flexible stalk attached?
If so, I've had to junction these before because they were too short...stick with the #6. Changing this would probably void your warranty with generac.
VA master elect is offline   Reply With Quote
Generator Transfer Switch Trouble wgramer Electrical 23 11-12-2011 08:23 PM
help wiring a DPDT pushbutton switch fromscratch Electrical 9 10-11-2011 10:26 PM
Wiring a New Light Switch but Problems nlsnrn Electrical 8 08-31-2011 04:36 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 03:44 PM
4 way switch wiring ponch37300 Electrical 9 02-16-2009 10:58 AM
