Generac Expert Needed Wiring Old Gen To New Ats - Electrical - DIY Chatroom Home Improvement Forum
Old 10-31-2012, 10:18 AM   #1
Generac expert needed wiring old gen to new ats
I have a generator with the 194/23 N1/N2 connections for the transfer switch and the transfer switch has the 178/183 terminals to the generator. I have looked at a few newer model gens and they are equipped with both leads. The 183/178 looks to go the the start/stop switch to start the generator from the ats. The 194/23 wire from the generator appear to tell the ats to switch. I need to know if I can just rewire the start switch to the ATS so that the ATS controls the generator. I have a GTS "W" type ATS and a 16kw generac (52540).
Both the switch and the gen have a PCB and settings to control test runs, start up warm up, shut down cool down, and power sensors for switching. The only thing is the N1/N2 that power the charger are not set-up in the ATS. I will have to either run them through a fused connection or install a charger in the generator from a another power source.
donniep31 is offline   Reply With Quote
Old 11-01-2012, 03:20 PM   #2
I think I have a solution just need someone to confirm it. The generator will start with the loss of power to the N1/N2 input and the switch will switch once it sees the power from the N1/n2 loss and e1/e2 power supply active. By running a fuse connection to the generator I can stilll power the charger and it will also start the generator when the power is lost.
Old 11-04-2012, 01:22 PM   #3
Does any one have a suggestion of a site where I could get some help with installing this generator and making it operate correctly.
Wiring Diagram for ATT NID box needed cm6848 Electrical 5 02-08-2016 07:34 PM
Carpet Install expert advice needed Cruisinfanatic Flooring 5 05-10-2012 04:10 PM
Digital timer - help with symbols and wiring needed rsmattish95 Electrical 5 01-16-2012 06:29 PM
Wiring Help Needed aced19 Electrical 17 03-30-2009 09:30 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
