Gen XFR Switch & Tandem/Duplex Breakers - Electrical - DIY Chatroom Home Improvement Forum
Old 10-26-2012, 07:06 AM   #1
Rewards Points: 77
Gen XFR switch & Tandem/Duplex breakers
Hi Guys/Gals,
There's no restrictions on using a Manual XFR switch with tandem breakers, right?
I'm Planning to install that this weekend. Winter coming which could mean power outages.
Thanks,
~S
Skelleyman is offline   Reply With Quote
Old 10-26-2012, 07:27 AM   #2
Licensed electrician
Rewards Points: 1,634
To supply 240 to your panel you need a breaker that connects to both hot legs. Most tandems only hit one leg.
Old 10-26-2012, 10:15 AM   #3
Rewards Points: 77
Thanks Jim. So I'm not having to power any 240v circuits from my generator so I should be good right? The 6 circuits I want to put on my manual XFR switch are 15A or 110/120v so I should be able to power up a device that's on a tandem breaker/circuit, right?
Old 10-26-2012, 10:17 AM   #4
Every other breaker in a typical panel is fed by the opposite hot leg of the one next to it. If you only supply 120 to the panel only half of it will work.
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 07:25 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 10:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
