GEC Touching Metal Building - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-14-2014, 02:51 AM   #31
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Originally Posted by Jim Port View Post
The resistance of the neutral will be many times lower than earth. The high resistance of earth is why the GEC never needs to be larger than #6.
The concrete in the footer stays moister than the earth around a ground rod and also has many times the contact area compared to a rod.
That makes sense when put in simple terms like that.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 06-15-2014, 10:32 AM   #32
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Originally Posted by MTN REMODEL LLC View Post
It may/might .... depends on voltage and resistivity
The devils in the details ... I am assuming here since you do not give details .. you say " It provides a path to complete the circuit no? " So what exactly do you mean ? Give an example how it would complete a circuit for your home via the GEC.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
windows for metal building. Cheap but good viper Windows and Doors 1 01-14-2014 06:37 AM
Metal Studs in Metal building with horizontal support 7SistersRanchTX Building & Construction 1 03-06-2012 05:56 PM
Building a Metal vine covered pergola. dakkon Building & Construction 0 03-04-2012 08:10 PM
Multi rib metal roof on double wide...static vents wpilotm Roofing/Siding 0 09-10-2011 03:51 PM
Can I frame with wood on a building instead of metal studs EHouse Kitchen & Bath Remodeling 4 01-12-2011 10:19 PM
