GEC Touching Metal Building - Electrical - DIY Chatroom Home Improvement Forum
Old 06-12-2014, 12:17 PM   #1
Rewards Points: 97
We just built a wood framed building with metal siding and roof. The GEC runs out the bottom of the panel, down the stud bay, and out through a hole in the metal siding down at the bottom plate. Any problem with the GEC touching the metal of the building?
PS- I posted exact same question on another forum in case you come across it over there.
DBoone is offline   Reply With Quote
Old 06-12-2014, 12:47 PM   #2
Licensed electrician
Rewards Points: 1,876
The metal siding should be bonded to the GEC.
plummen (06-12-2014)
Old 06-12-2014, 01:06 PM   #3
Rewards Points: 3,396
It's metal siding.
How will each piece of siding "bond" to the next piece.
It is siding not structural steal.
No "bonding" necessary. But couldn't hurt if you "tried". IMO.
ritelec is offline   Reply With Quote
Old 06-12-2014, 09:12 PM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Not required...
Old 06-12-2014, 09:22 PM   #5
Rewards Points: 455
Originally Posted by ritelec View Post
It's metal siding.
I agree it's not necessary, but, watch for the 2017 code or maybe the 2021. Remember, the water bond rule....
Cletis is offline   Reply With Quote
Old 06-12-2014, 09:48 PM   #6
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I'd bond it to the egc, what the heck I've seen chain link fence get energized why not metal siding.....
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
The Following 2 Users Say Thank You to Stubbie For This Useful Post:
mpoulton (06-15-2014), plummen (06-12-2014)
Old 06-12-2014, 09:52 PM   #7
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
It's metal siding.
I would think the siding is fastened together with screws/mechanical connection of some sort.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
Stubbie (06-12-2014)
Old 06-12-2014, 10:20 PM   #8
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,786
OK.... So this thread, disregarding code for a moment. made me wonder about a theoretical based question......
Do not we put a ground rod on a home to somewhat attract a lightening charge away from the home and to a better ground source ...the ground rod system.
So, if we ground steel siding with a #6 ground, are we not attracting lightening to an undersized grounding system.
I'm sure this is dumb, help straighten out my thinking/understanding.
TIA
(Although it is somewhat theoretical, the question does go to whether, and whether not, it will or should be future code.)
MTN REMODEL LLC is online now   Reply With Quote
Old 06-12-2014, 11:03 PM   #9
plummen's Avatar
Well if you really want to get technical if the building has its on service and meter socket attached to the outside its already bonded to the electrical service/grounding through the metal siding.
They make you bond the rebar in garages when installing an electrical service,personally I see more potential in steel siding becoming energized than the rebar in the floor/walls anyway.
Old 06-12-2014, 11:23 PM   #10
Well... Isn't the UFER grounding (rebar in foundation) a grounding component of the GEC and not done as an issue of becoming energized as in the bonding (equalpotential) function of the GEC.... if that made sense.
I guess I'm saying the run to the rebar (UFER) is to establish a ground, and any bonding to the steel sideing would be to establish equal potential if the siding became energized.... sorta two differnt functions/objectives.
But, a pretty good point.... seems if we bond pipes and Jacussi motors to make sure they are at ground potential, does seem we outta ground steel siding which seems it could get energised also.
Not that I wanna go there.... just discussion
Old 06-13-2014, 12:41 AM   #11
UAW SKILLED TRADES
Stubbie's Avatar
I see no reason to include metal siding on a wood frame in the bonding of the grounding electrode system. However I would entertain an argument about the metal siding being "likely to be energized" and should be bonded to the EGC. Even if energized ... and I'll bet there is someplace out there that has metal siding energized ... it would be difficult to provide a good enough bond via the fasteners on each panel to clear a fault. It would be one thing to read voltage on a panel but the fault would likely not clear if a single panel is bonded to the egc unless that is the origin of the fault. You likely would have to bond each panel. Seems like there was an FPN about metal siding I'll see if I can come up with it assuming my memory is correct ...
Mike Holt forum probably has a discussion about metal siding, they hash over just about everything imaginable ....
Stubbie
The Following User Says Thank You to Stubbie For This Useful Post:
zappa (06-13-2014)
Old 06-13-2014, 05:54 AM   #12
Rewards Points: 774
If it is aluminum siding bonding the siding is not only impractical but useless as the aluminum is coated and any exposed joints will oxidize. If it is overlapping steel it is coated as well and one would need to bond all separate pieces.
Know A Little is offline   Reply With Quote
The Following User Says Thank You to Know A Little For This Useful Post:
zappa (06-13-2014)
Old 06-13-2014, 06:18 AM   #13
E2 Electrician
Lets not forget that bonding metal objects is a good way to energize items that should never be energized, if a utility company should lose a neutral conductor, everything bonded will become energized!
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
MTN REMODEL LLC (06-13-2014), Stubbie (06-23-2014)
Old 06-13-2014, 06:50 AM   #14
Rewards Points: 3,256
Ground rods will save the day.
zappa is offline   Reply With Quote
Old 06-13-2014, 07:03 AM   #15
Rewards Points: 97
Yep it has it's own service and meter.
There will be a little current on the GEC going to the ground rod and to the utility pole so I was thinking maybe current would be all over the metal siding, through the slab, back to utility pole. Didn't want to have any problems.
But you're right. The meter is mounted to the metal siding already so I can't see there being any extra issues with the GEC touching the metal siding.
windows for metal building. Cheap but good viper Windows and Doors 1 01-14-2014 06:37 AM
Metal Studs in Metal building with horizontal support 7SistersRanchTX Building & Construction 1 03-06-2012 05:56 PM
Building a Metal vine covered pergola. dakkon Building & Construction 0 03-04-2012 08:10 PM
Multi rib metal roof on double wide...static vents wpilotm Roofing/Siding 0 09-10-2011 03:51 PM
Can I frame with wood on a building instead of metal studs EHouse Kitchen & Bath Remodeling 4 01-12-2011 10:19 PM
