Old 07-09-2011, 03:59 PM   #1
Ge Washing machine
I just recently replaced my timer due the fact it would fill up with water ,spin but not agitate on any cycle. After installing the part this morning I tested it and and went through a normal wash cycle. When I tried again a few hours later it did the same thing as before it would fill up with water ,spin but not agitate. I am assuming since it does spin the belt is fine. At this point I don't know if I have something shorting it out or I have a bad switch lid which is magnetic or if I have a bad rely. Also I would I bypass the lid switch on this machine so that I can see if that is the case.
Thanks,
Brian
BBargeron is offline   Reply With Quote
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 04:30 AM
Trouble with washing machine drainage wfischer Plumbing 3 05-15-2011 06:10 PM
Washing machine and dedicated circuit.... ? CoconutPete Electrical 15 11-16-2010 09:02 PM
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 09:25 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 12:17 PM
