Ge Washer Wpre8150k1wt - Electrical - DIY Chatroom Home Improvement Forum
Old 07-13-2012, 09:00 PM   #1
Question
Ge washer wpre8150k1wt
My washer works all codes have been cleared by my husband. Washer will still not fill with water it wants to drain when turned on Dear husband very frustrated
RDLL4Y3 is offline   Reply With Quote
Old 07-13-2012, 10:50 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Warranty?
Old 07-14-2012, 12:29 AM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Probably a repair technician is your best bet.
There are a few things you as a diy can check as far as the no fill problem. I'm not sure though about what you mean by it wants to drain.
Anyway disconnect the two hoses from the back of the washer and you will see two screens. They may be clogged with iron deposits. Cean them.
If you husband is handy he may want to check to make sure the water inlet valve is working.
As for the draining. Are you saying that when you turn the washer on to start the cycle ...motor and pump start and it begins to pump the water out of the washer.
Old 07-14-2012, 12:36 AM   #4
Master Electrician
Probably the wrong forum as it has nothing to do with electrical.
Whatever tells your washer that its time to drain obviously isn't working right. I would assume you need the Maytag man :D
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 12:00 PM
Washer & Dryer Holiday Fun BRIANisMEisWE Appliances 8 12-24-2011 03:41 AM
MayTag Neptune washer leaking door Ufers5 Appliances 4 12-06-2010 02:01 PM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
Moving Washer and Dryer upstairs from basement pennypoopie General DIY Discussions 3 08-23-2009 06:29 PM
