GE SunSmart Timer 15312 Install - Electrical - DIY Chatroom Home Improvement Forum
Old 01-15-2012, 06:28 PM   #1
I am replacing an Intermatic timer with the subject timer. I've installed the timer per the instructions and cannot get power to the device. Wired per the instructions: black house to black timer, white house to white timer, copper house ground to green timer, red house jumper from red/black bundle (three lamps) to blue timer, capped red as unused. Single pole installation. One switch, three exterior coach lamps. Purchased second identical unit and installed with same results. Did I wire incorrectly?
DonSmith is offline   Reply With Quote
Old 01-15-2012, 06:48 PM   #2
Licensed electrician
Rewards Points: 1,284
If the white was connected to the switch it was a hot wire and not a neutral. I suspect your switch requires a neutral that may not exist in your switch box.
Old 01-15-2012, 07:09 PM   #3
The Intermatic timer replaced had only black, blue, & red - black house to black timer, red house jumper to blue timer, and red timer capped. On my first install of the GE unit, I left white timer capped, but with same results. House constructed 1989, would it not have black/hot, white/neutral, green(copper)/ground wiring as code?
Old 01-15-2012, 07:41 PM   #4
Rewards Points: 6,652
Why does this topic sound familiar. Hmmn installing timer to 3-way switch
See link in the above post for wiring diagrams.
Old 01-16-2012, 11:30 AM   #5
Swapped the timers blue and black inputs from the house and got power to the device. Now onto programming.
The Following User Says Thank You to DonSmith For This Useful Post:
gregzoll (01-16-2012)
Installation of a SunSmart Digital Timer PJR Electrical 4 04-26-2012 07:33 AM
wiring a single pole ge sunsmart digital timer arthurspoon Electrical 3 01-04-2012 02:47 PM
GE Sunsmart Digital timer appears to be dead michaelhager Electrical 5 11-26-2011 11:52 PM
GE Smart Digital Timer Will Not Work Manually dgbarar Electrical 3 10-31-2010 09:15 PM
Install an electronic timer CaJazzman Electrical 8 08-13-2008 05:12 PM
