GE Sunsmart Digital Timer Appears To Be Dead - Electrical - DIY Chatroom Home Improvement Forum
Old 11-26-2011, 09:22 PM   #1
GE Sunsmart Digital timer appears to be dead
Bought a GE Sunsmart Digital Timer 15312. Wired it as instructed: black to black, blue to black, white to white (neutral) and green to ground. Red discarded as this is a single pole installation. Only switch to porch light.
The unit is dead. Pushed reset button in for 3 seconds, nothing. Double checked all connections, nothing. Removd and installed old switch, no problems light goes on. Took unit back to Home Depot and got a second unit. Hooked it up: nothing.
Any ideas? Is there a button sequence I'm missing?
michaelhager is offline   Reply With Quote
Old 11-26-2011, 10:32 PM   #2
Msradell's Avatar
Rewards Points: 90
Could you have the blue and the black wires connected to the wrong blacks? The black from the timer should be connected to the power feed and be always on, the blue should be connected to the black that goes to the device you're controlling. If you're working inside of an existing box it's very easy to mix up the 2 of them.
Msradell is online now   Reply With Quote
The Following User Says Thank You to Msradell For This Useful Post:
michaelhager (11-26-2011)
Old 11-26-2011, 10:51 PM   #3
a light switch dosent have a neutral wire normally, its just power in and power out. if you look into the back of the box the switch is mounted in do you see two white wires with a wirenut on them? if so these are your neutrals. so its black from new sw. to black from the box. white from the wires that are wirenutted in back of the box(just add the white from the switch to the wirenutted group so there will be 3 wires in that wirenut now.) and blue to black.
ok something just dawned on me did you seperate the white wire from another one if so all 3 have to be tied togeather look at the picture at the top right of the install diagram see #2 where 3 wires are nutted togeather?if that still dosent work swap the wires on the black and blue connections. perhaps you have the line side attached to the load side and vice versa. let me know what happens the suspence is killing me
ok just read the directions more throughly and i see it tells you all that stuff about the neutral wire so now im just gonna say swap the blacks that go to the blue and black on the switch
kennzz05 is offline   Reply With Quote
Old 11-26-2011, 10:54 PM   #4
Msradell...
The wireing diagram showed the black wire connected to the wire coming from the top of the box and the blue wire attached to the wire coming from the botton of the box. It never occurred to me that it could be reversed.
I stand sheepishly grinning... works just fine. Thanks!
Old 11-26-2011, 11:20 PM   #5
Msradell's Avatar
Rewards Points: 90
Glad it was something simple and easy to fix!
Old 11-26-2011, 11:52 PM   #6
kudos to all yea
Tags
deadswitch
Problems, GE SunSmart Digital Timer 15312 Mike Muls Electrical 41 07-30-2016 09:13 PM
GE SunSmart Digital TImer lilacorn1956 General DIY Discussions 4 04-23-2012 06:37 PM
Programming the GE Sunsmart digital timer Maris Electrical 0 09-26-2011 05:57 PM
GE Smart Digital Timer Trevis Electrical 21 09-08-2011 11:17 PM
GE Sunsmart Digital Timer Installation dtn311 Electrical 1 08-01-2011 02:16 AM
