Old 07-14-2012, 06:21 PM   #1
GE sunsmart digital timer to 3 way circuit. Help!
Hi all,
I am trying to install the GE Sunsmart Digital timer. I've read the instructions and tried every possible configuration...that being said, I know nothing about electrical wiring. I do know it's a 3 way circuit. The timer has multi-colored wires. I do think I am correct that the ground is connected to the green and perhaps timer white to white bundle. Beyond that I'm clueless.
original switch
attempt at attaching switch wires
Any input would help. I don't know if it is "load side" or not. There is also a separate short black wire that is separate included (I have no idea what that's for...jumper perhaps?)
Thanks!...
rsa130 is offline   Reply With Quote
Old 07-14-2012, 06:22 PM   #2
Old 07-14-2012, 07:08 PM   #3
And I did check the other forum posts on this topic! None of the circuits look quite like this one!!
Old 07-15-2012, 11:44 AM   #4
If someone could just explain the in-wall circuit
Old 07-15-2012, 01:20 PM   #5
Your old switch looks like a 4-way switch. I assume this switch is controlling a light.
How many other switches, besides the one pictured, control the same light?
GE sunsmart digital timer to 3 way circuit. Help!-4-way.jpg   GE sunsmart digital timer to 3 way circuit. Help!-types-switches.jpg
hammerlane is offline   Reply With Quote
Old 07-15-2012, 02:13 PM   #6
Thank you so much for your response!!!
There are 2 others! The other two look like 3 ways (I think). The 1st switch in the series looks like the one below. I tried it first and got the lights to turn on, but then they shut off immediately, as if it short-circuited.
Your thoughts on setting this one up...
Old 07-15-2012, 04:17 PM   #7
You cannot use that timer to replace a 4-way switch.
Old 07-15-2012, 06:43 PM   #8
Thank you again! I finally got it working. I just had to make sure I was using a unipolar switch!! I never would have realized the 4-way I was using was the wrong type. Thanks :thumb up:
GE SunSmart Timer 15312 Install Issue stringzz Electrical 10 02-06-2012 09:17 PM
Digital timer - help with symbols and wiring needed rsmattish95 Electrical 5 01-16-2012 07:29 PM
GE Sunsmart Digital Timer Installation dtn311 Electrical 1 08-01-2011 02:16 AM
wiring ge smart digital timer jesse liang Electrical 1 05-11-2011 06:20 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
