GE SunSmart 15312 3-way Installation Challenge. - Electrical - DIY Chatroom Home Improvement Forum
Old 07-13-2012, 12:50 PM   #1
GE SunSmart 15312 3-way installation challenge.
Hello, I have a GE SunSmart 15312 3-way installation challenge and need help connecting the wires correctly.
I would like to install the GE swith in the upstairs part of a 3-way setup.
Upstairs has two(2) cables - Cable-1 W/Black and White Wires, Cable-2 W/Black, White, Red, Green Wires.
The White from cable-1 is connected to the Black from Cable-2.
The existing upstairs 3-way switch is wired as follows: Cable-1 Black to Common, Cable-2 White to terminal, Red to terminal, Green to Gound.
The downstairs has 1 cable W/Black, White, Red, Green wires; wired Black to Common, White to terminal, Red to terminal, Green to Ground.
What is the correct connection of the Black, White, Red, Blue wires from the GE 15312 to the cables/wires in the upstairs box? Help...
Rob
RobGrantt is offline   Reply With Quote
Old 07-13-2012, 03:40 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 252
You can't use it in the upstairs box because you do not have a neutral wire.
jbfan is online now   Reply With Quote
Old 07-13-2012, 04:09 PM   #3
Thanks for the reply jbfan. Would you be so kind as to explain how then to install the GE switch in the downstairs box?
Rob
Old 07-13-2012, 05:37 PM   #4
jbfan's Avatar
Rewards Points: 252
Unfortunately, you have the same situation in the downstairs box also.
Old 07-13-2012, 07:17 PM   #5
Master Electrician
nothing like kicking a guy while he's down lol.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-14-2012, 08:53 AM   #6
Rewards Points: 2,516
I imagine this is your current setup. By the way good explanation in the wiring setup in each switch location. Like that you identified cables and wires. I do not show any ground wires in the diagrams just for ease of drawing.
GE SunSmart 15312 3-way installation challenge.-3-way-power-lite-switch-loop-2.jpg
hammerlane is offline   Reply With Quote
Old 07-14-2012, 08:56 AM   #7
To remedy your situation if you could replace the 12-2 running from the light location to the up switch location with a 12-3 cable, you could have a neutral wire at the upstairs switch location
GE SunSmart 15312 3-way installation challenge.-3-way-power-lite-switch-loop-2-12-3-neutral.jpg
Old 07-15-2012, 09:23 AM   #8
Thank you all for your replies and input. Will I have this issue with any 3-way timer or is there one you might know of that bypasses this issue?
Rob
Old 07-15-2012, 09:44 AM   #9
Rob
If you do not want to fish a another cable that includes a neutral to the switch location, You need to find a 3-way timer that does not need a neutral wire which may be hard to find
Tags
ge sunsmart 15312
Problems, GE SunSmart Digital Timer 15312 Mike Muls Electrical 41 07-30-2016 09:13 PM
Installation of a SunSmart Digital Timer PJR Electrical 4 04-26-2012 07:33 AM
GE SunSmart Timer 15312 Install Issue stringzz Electrical 10 02-06-2012 09:17 PM
GE SunSmart Timer 15312 Install DonSmith Electrical 4 01-16-2012 11:30 AM
GE Sunsmart Digital Timer Installation dtn311 Electrical 1 08-01-2011 02:16 AM
