#1 |
ge sub panel mystery
I bought a ge TLM612 sub panel. The breaker bus does not allow breakers in the #6&8 positions. I need the full 16 circuits. Does anyone know if that breaker bus can be exchanged for another type that will let me use all 16 circuits????
#2 |
Licensed Electrician
You need the GE "thin" breakers. That's what the 6 & 12 is for in the model number.
Don't go changing the buss bar, get the right breakers.
Union County, NJ, Licensed Electrician To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 | |
You talking to me?
ge sub panel mysteryQuote:
the two you want to put a breaker into are not made to accept a breaker. if you want more circuits, you need to buy a larger panel. |
#4 |
The problem is that with this breaker buss the manufacturer has made it so you can not put breakers in the 6 or 8 slots, that would be the last two on the right side. It does not matter if you use regular or 1/2 size breakers. Why would the manufacturer block out two slots? That is why I thought you might be able to get another breaker buss.
#5 |
Spend 30 bucks and get a proper panel.
#6 |
Thanks nap, Why would the cardboard box it came in say 8 or 16 circuits, maybe a packaging error??? I don't understand the panel box itself is still just a metal box like any other...why can't a different buss for breakers go in it or do they not make such a critter. Seems wierd to me.
#7 | |
You talking to me?
go to this site and to page 18 (20 on the pdf reader page read out). On the right, they will show you the layout for the 612 panel. I don't even see an 816 panel. I saw an 812 though. http://www.geindustrial.com/publibra...CDET-222%7CPDF if you notice, there is a legend at the top of that page. Light breaker spaces are for 1" breakers only and the darkened spaces can use 2- 1/2" breakers if you remove the bus, unless you had one made specifically for that tub, it would not be UL listed and as such, you could not use it. Last edited by nap; 12-01-2009 at 12:01 AM. |
#8 |
Thanks again I guess it's the 812 box I need. There has to be something with the buss metal thickness. Oh well it's still wierd to me.
#9 | |
You talking to me?
Square D does this as well but they just set it so the bottom 2 spaces are not usable rather than the odd configuration of the 2 on one side. It is quite misleading to see the knock outs for the breakers and not have the bus behind them to be usable. |
| Display Modes | |
| 100 -> 200 amp panel upgrade questions | philipjcaputo | Electrical | 1 | 10-30-2009 04:35 AM |
| Replacing 2 Sub Panels with 1 Larger Panel | GuitarJack | Electrical | 7 | 08-25-2009 09:43 PM |
| Replacement Meter Panel | leonard_voet | Electrical | 19 | 04-09-2008 11:27 AM |
| Installing new (service?) breaker panel and generator panel | Nhrafan | Electrical | 6 | 04-01-2008 04:03 PM |
| large mystery plywood panel in garage - any thoughts on this?! | joeyboy | General Discussion | 15 | 12-02-2007 04:01 PM |
