Ge Smart Digital Timer - Electrical - DIY Chatroom Home Improvement Forum
Old 01-31-2011, 12:47 PM   #1
ge Smart Digital Timer
I tried to install the Timer yesterday to control my front porch light. It will only contiually flash on and off. I think I may have reversed to the black to black and the black to red wires. Any thoughts before I go back in.
davsam is offline   Reply With Quote
Old 01-31-2011, 01:01 PM   #2
This usually means that your neutral is not correctly wired to the switch. Unlike a single-pole switch, most digital timers require a neutral. You should have four connections on the timer:
  • hot lead (connect to incoming hot lead from the circuit breaker)
  • load lead (connect to outgoing hot lead to the light fixture)
  • neutral lead (connect to the neutral lead from the main panel and to the neutral lead from the light fixture)
  • ground lead (connect to the ground conductor from the main panel and to the light fixture).
It is possible that your original switch was on a switch loop and there is not a neutral conductor in the device box; if this is the case, you will need to pull a neutral conductor into the device box to make the digital timer work properly.
clashley is offline   Reply With Quote
Old 01-31-2011, 03:28 PM   #3
The smart switch is one of four switches in the box. Do I need to match the neutral wire with the actual switch, or will any one of the four wires work off of the bundle?
GE Smart Digital Timer Trevis Electrical 21 09-08-2011 10:17 PM
GE Digital Smart Timer chinook Electrical 1 01-06-2011 07:48 PM
GE Smart Digital Timer Flashes Hawkus1939 Appliances 4 12-22-2010 11:17 AM
GE Smart Digital Timer Will Not Work Manually dgbarar Electrical 3 10-31-2010 08:15 PM
Wiring GE Smart Digital Timer to 3 way switch. Wing Electrical 16 08-26-2010 06:22 PM
