GE Smart Digital Timer 7 Day Model 15071 - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2011, 04:27 PM   #1
GE Smart Digital timer 7 day model 15071
I have it programed, but when I push the manual override the lights click on and off and do not stay on.
What have I done Wrong?
Chas
Charleswwest is offline   Reply With Quote
Old 01-14-2011, 07:02 PM   #2
Chas
A blinking light from these timers usually indicates the neutral is not properly wired to the switch. Exactly how did you wire this switch?
clashley is offline   Reply With Quote
Old 10-20-2012, 10:18 AM   #3
I also have the 15071 and found the same problem. I have a very complicated box I'm trying to wire into that has four switches. Two of which, to my knowledge, don't do anything. The rocker switch I am replacing controlled our front porch light. When I wire it as the previous switch was wired, I get this same result of the light turning off when I turn it on. All the white wires in the box are bound together with a wire nut. When I wire the white wire from the switch into this grouping the light doesn't turn on at all.
Any suggestions would be greatly appreciated!
jpzurf is offline   Reply With Quote
GE Smart Digital Timer Trevis Electrical 21 09-08-2011 10:17 PM
GE Digital Smart Timer chinook Electrical 1 01-06-2011 07:48 PM
GE Smart Digital Timer Flashes Hawkus1939 Appliances 4 12-22-2010 11:17 AM
GE Smart Digital Timer Will Not Work Manually dgbarar Electrical 3 10-31-2010 08:15 PM
Wiring GE Smart Digital Timer to 3 way switch. Wing Electrical 16 08-26-2010 06:22 PM
