GE Smart Digital Timer - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-06-2011, 01:41 AM   #16
jbfan, what is the solution to Chinook's question? I have the same question. thanks.
Gundish is offline   Reply With Quote
Old 03-06-2011, 08:33 AM   #17
jbfan properly pointed out "If you only have one of each color in the switch box, you have a switch leg and can not use this timer. This timer requires a neutral to work" which is the correct solution.
What I need was the Intermatic ST01C model. For some reason I couldn't find one locally, so I researched online and found the best prices at WestsideWholesale.com - $29. Goodluck.
chinook
chinook is offline   Reply With Quote
Old 03-06-2011, 03:12 PM   #18
Ge 15086
Thanks Chinook and JBFan for the wiring advice. Don't know why the instructions can't do the same.
Old 07-12-2011, 06:36 PM   #19
I have the same timer as the original poster asked about, same wires, same instructions. My switch is not a three way, but it's in a triple box with two 3 way switches. I have a bundle of white wires - how will I know which two white wires are the appropriate ones for the main and load neutrals? While I'm at it - how will I know which are the main and load hots? I'm going to try to include a picture of my box, the timer will go on the left
Homerenodad is offline   Reply With Quote
Old 07-13-2011, 04:01 PM   #20
Would a different angle picture help?
Old 09-08-2011, 11:05 PM   #21
hello
to connect the timer you will need to check which wire has power, by using a tester or pick tail connect one side of the tester to the ground or the box if it's metal. the one with power connect to the black wire of the timer the second wire of the switch connect to the red wire of the timer the ground wire connect to the green wire if you don't have a ground wire jus cap the green wire, then look for two white wires connected inside the box if you have the white wires connect the white wire of the timer to the two wires. if you don't have white wires in the box you can make it work but it' not so legal connect the white wire with the ground it should work
bsirota is offline   Reply With Quote
Old 09-08-2011, 11:17 PM   #22
hello homerenodad
that boundle of white wires with the red wire nut should be your neutral, connect the white timer wire to that white bundle. then use a tester or picktail 1 side to the metal box and the other side to 1 of the wire of the switch when light of thester works that means that this is the power and connect that wire to the black timer wire and the 2nd wire from the switch connect to the red wire of the timer the green wire connect to the box with a screw if possible it should work
Wiring GE Smart Digital Timer to 3 way switch. Wing Electrical 16 08-26-2010 07:22 PM
Intermatic Digital In-Wall Timer ST01C themayor Electrical 9 03-02-2009 06:14 PM
Help with digital timer wiring longman Electrical 7 12-06-2008 12:22 PM
Digital timer problems bazzer Electrical 4 11-20-2006 06:44 AM
