#1 |
GE main panel neutral bar full -- options?
I'm adding a subpanel for a basement finish and it looks like I have insufficient room in the main panel's neutral bar to connect the neutral for the subpanel.
Here is the main panel with the subpanel feeder entering from the top. The unconnected wire with the white stripe is the one I'm having trouble with. ![]() Neutral bar detail: ![]() The main panel is a GE TX2415 RH originally installed in 1979. So, does anyone know if there is a larger neutral bar I could use in the main panel, or an "expansion" neutral bar? -- I do (possibly) have another option, but it would involve rerouting the subpanel feeder, which is not my idea of fun (it's a 1/0-1/0-1/0-2 Al SER). The house also has a separate 150 amp service for an electric furnace that has long since been removed. Perhaps I could replace the existing 150A furnace breaker (picture below) with a 100A, and connect the here instead? It looks like I'd need a GE TQD22100 breaker (which are rather pricey and may not be manufactured any more) and also a different neutral lug to connect the incoming (yellow) neutral and earth ground to the subpanel feeder's neutral and ground. ![]() Thoughts? - Bill |
#2 |
Licensed electrician
The proper thing to do is to add a grounding bar and move all the copper grounding conductors to the new bar. As it is now the grounding conductors are not properly terminated. That lug is for one conductor, not many.
Answers based on the National Electrical Code. Local amendments may apply. Check with your local building officials. Last edited by Jim Port; 03-31-2012 at 09:20 PM. |
| The Following 3 Users Say Thank You to Jim Port For This Useful Post: |
#3 |
retired elect/hvac/plumb
Or even better why not just replace that outdated existing panel with a new panel big enough to handle everything,then you wont need a sub panel?
"facts" have no relevance to this discusion To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Posting from a concrete bunker under a non descript barn |
| The Following User Says Thank You to plummen For This Useful Post: | ddawg16 (03-31-2012) |
#4 |
Electrical Contractor
Would be much easier to replace the panel with separate neutral and ground bar so you can make it neater.
Looks to me like it should be treated like a sub panel anyways.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe. Last edited by rrolleston; 03-31-2012 at 09:27 PM. |
#5 |
Licensed Electrician
It should be treated as a subpanel because it is a subpanel.
#6 |
Licensed Pro
You could add a ground bar as previously noted, but I would strongly suggest you replace that old spilt bus panel with a new one.
"Life is hard. Life is harder when you're stupid." John Wayne |
#7 |
If I read it right that outside disconnect in the picture is for a seperate service,and is not feeding that GE panel.
#8 |
you appear to be right
#9 |
Thanks for the suggestions.
A clarification -- The panel I called the "main" panel I guess technically is a split-bus subpanel. There are two main breakers in a pedestal with the meter at the corner of the property, each 150 amp. One supplies the split-bus panel and the other supplies the old electric furnace's panel (both attached to the house, but separately supplied from the meter). The subpanel I'm adding (whose neutral I'm having trouble connecting) is inside the house, and would be supplied from either the split-bus panel (or its replacement) or the old furnace panel. It sounds like the *best* option is a panel replacement, but I was looking to avoid that in case some of the new, expensive code requirements (like AFCIs) would apply. I thought the ground wire connections looked strange (all under one lug), but the builders did it like that. Perhaps that was normal 33 years ago? Or they were just lazy. - Bill |
#10 |
AFCI's are not required to be installed on a panel change. You could double check with the AHJ, but I'm fairly certain you won't be required to do so.
So, that split buss panel is a subpanel? Then those neutrals and grounds need to be separated. |
| The Following User Says Thank You to k_buz For This Useful Post: | plummen (04-01-2012) |
#11 |
So, that split buss panel is a subpanel? Then those neutrals and grounds need to be separated.[/quote]
I may be mangling my terminology. I assumed "subpanel" to mean a panel without a main disconnect (or can the 2-pole breakers in the top section of a split-bus panel collectively be considered the "disconnect?"). This panel is the main electrical point of entry for the house, though, and is connected to the grounding rod. |
#12 |
If there is a main breaker/disconnect that turns off this panel somewhere other than in this panel, it is a subpanel.
#13 |
The split bus panel has the wire from the ground rods?
#14 |
Yes -- the ground rod is connected to the split bus panel and also to the electric furnace disconnect panel.
![]() - Bill |
#15 |
Ground rods need to be connected at the main service, that being on the line side of the main disconnect. That being said, there may be some local codes that would come into play whether it be from your community, or the POCO.
Today's code would require you to have rods at both the main service location, and at the house due to the feeders running underground. Do you know that the split buss panel goes specifically to ground rods, or are you assuming it goes to ground rods? The reason I ask, is that your house's water system should be bonded to those panels. You might be seeing the "water ground" and are assuming the wire goes to ground rods and I do believe the panel and disco at the house should be bonded together (without searching my code book). Last edited by k_buz; 04-01-2012 at 01:26 AM. |
| Display Modes | |
| Service move - old panel, separating neutral and ground | WillK | Electrical | 3 | 06-17-2011 09:18 AM |
| main to sub panel conduit/wire run | daddyrabbit | Electrical | 7 | 02-12-2010 08:12 PM |
| sub panel ground and neutral | daddyrabbit | Electrical | 3 | 01-29-2010 07:49 AM |
| Adding ground bar to main panel | WoodworkerDave | Electrical | 6 | 09-27-2008 05:52 PM |
| Main Service Panel Full | bobo | Electrical | 5 | 09-24-2007 08:13 PM |
