GE Load Center Nomenclature - Electrical - DIY Chatroom Home Improvement Forum
Old 10-27-2010, 01:57 PM   #1
GE Load Center nomenclature
Can anyone help me in deciphering GE PowerMark Gold Load Center product nomenclature?
What does the "P" indicate on these panels?
TLM612SCUDP
TLM612SCUD
I've been scratching my head at this one. Everything about them looks identical.
Thanks!
kb01 is offline   Reply With Quote
Old 10-27-2010, 02:11 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I can't find it on GE's site.
You might contact GE and ask.
does one come with and one without breakers maybe "P"= package?
Old 10-27-2010, 02:35 PM   #3
I'm actually wondering if the P indicates an update. The panels look identical on the outside but the plastic insulators that separate the neutral bar from the box look more robust on the "P".
From what I can ascertain.
TLM612SCUDP
S = Surface Mount
CU = Copper Bus
D = Comes with door
Old 10-28-2010, 01:15 AM   #4
" Euro " electrician
frenchelectrican's Avatar
That is little odd numbers but you have 6/12 space setting so it mean you have 6 space full size or 12 space half inch breakers or Twinners depending on which breaker you snag on GE products there are few diffrent verison so watch out which breaker you get them espcally if you want 2 pole one inch verison this can get tricky if not carefull.
As far for P stand there are two items It kinda came to my mind either Package or seperated ground bussbar including not sure but I will look up the GE master catalog book to make sure.
Merci.
Marc
Load Center Replacement Question EmilG Electrical 10 09-29-2010 12:11 PM
Help 30 amp Load center for my HID lights and miscellaneous Mont@n@ Electrical 9 03-06-2010 11:49 AM
Flush mount an outdoor load center? wmldwilly Electrical 1 04-29-2009 07:17 PM
Load center vs. bottom fed Panel Board. Ugh. wmldwilly Electrical 8 04-23-2009 07:48 PM
Termite repair to load center wall - precautions shepiii Electrical 3 01-21-2009 04:14 PM
