GE Digital Timer In 3-way Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 01-02-2011, 08:13 PM   #1
GE digital timer in 3-way circuit
Is there a way to use a GE digital timer model 15086 in a lighting circuit that has 2 switches? If not, does somebody sell a timer that does work in a 3-way switch circuit?
edtomeo is offline   Reply With Quote
Old 01-03-2011, 09:17 AM   #2
Rewards Points: 1,440
Do you want the timer to override the switches or do you want the switches to override the timer?
Do you want the override to be in the form of keeping the light on or keeping the light off?
Old 01-06-2011, 11:45 PM   #3
Sorry for the delay. My key objective is having lights on a timer. If there are no 3-way timers, I'd likely look to take the second switch out of service all together.
Old 01-07-2011, 02:09 AM   #4
3 way timers
GE does not make a 3-way digital programmable timer. GE makes a spring-wound countdown single-pole and 3-way timer 15305 available at Home Depot.
Other companies make a 3-way programmable timer, and the wiring is slightly different by brand, and you have to pay attention to wiring diagrams. Some require extra jumper wire at second switch because of the timer electronics. pay attention to which 3-way switch you are replacing: the one with Hot wire or the one with Load wire.
Intermatic EJ500 & ST01C
Brinks (Walmart) 46-1022
UPM timers: ETW193 & ETW350
Honeywell Aube: T1032 7-day, T1034 astronomic, T1070, T1073
Links to these timers, with images, information, manuals and sellers is shown on following page:
http://waterheatertimer.org/GE-timer...als.html#15086
Geno-3245 is offline   Reply With Quote
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 09:21 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Intermatic Digital In-Wall Timer ST01C themayor Electrical 9 03-02-2009 06:14 PM
Help with digital timer wiring longman Electrical 7 12-06-2008 12:22 PM
