Ge Digital Timer # 15086 Wiring? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2011, 09:17 PM   #1
ge digital timer # 15086 wiring?
I am trying to install a ge 15086 digital timer.
The switch to replace is a single pole switch with a black wire connected at the top and white at the bottom.
The ge switch has a white, black, red and green.
There is a second switch in the box which is a three way. It has a red, black, white and green.
The manual says to connect the red to the load, black to the line and white to neutral. Trouble is I only have two wires (white and black) coming in from the light fixture and this is old work so pulling a new 14-3 wire isn't an option.
I am assuming that the white and black is acting as a loop (two blacks).
Is it possible for me to use the white neutral from the three way switch in the box through a wiring nut to both switches? That would give me a neutral, red (white from the fixture) and black (from the fixture at the ge switch.
Thanks in advance for your advice.
Jamesy is offline   Reply With Quote
Old 01-08-2011, 09:40 PM   #2
Electrical Contractor
kbsparky's Avatar
NO. That white wire on the adjacent 3-way switch is most likely not a neutral.
You will need a different timer, one that does not require a neutral connection to operate.
-KB
Old 01-08-2011, 09:46 PM   #3
can anyone recommend a timer.
I am looking for something that can be programmed digitally so that I can have it turn on at 4pm and off at 10pm 7 days a week for example.
Thanks in advance
Wiring Aube T1071 light timer KathyK Electrical 9 12-24-2010 08:04 PM
GE Digital Timer bthomann Electrical 4 10-26-2010 07:00 PM
Wiring GE Smart Digital Timer to 3 way switch. Wing Electrical 16 08-26-2010 07:22 PM
Mechanical timer wiring? Duane 70 Electrical 5 06-16-2010 09:57 PM
Help with digital timer wiring longman Electrical 7 12-06-2008 12:22 PM
