GE 7 Day SunSmart Digital Timer - Electrical - DIY Chatroom Home Improvement Forum
Old 04-04-2012, 01:35 AM   #1
GE 7 day SunSmart digital timer
I only have 2 black wires and 1 white. The digital timer has 1 red,1 blue,1 black and 1 green. I connected my 2 black wires to black and blue accordingly, and the white to white. My timer turned on and I was able to set the time and programmed it to my set on and off time. Unfortunately, it didn't do what it supposed to do.What did I do wrong? Is it a wiring or a programming problem? Please help.
tomg is offline   Reply With Quote
Old 04-04-2012, 01:44 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
The red wire should be capped in the box, it is not needed in a single pole switch application.
The black of the timer needs to go to the line side black wire (the hot). The blue of the timer needs to go to the load side black (the switch leg). It is possible if you have 2 blacks in the switch box, that you got the two switched. If you have a voltage tester/meter you can check which black has voltage to neutral or ground. The black with voltage is your hot.
You could also just swap the blacks and wait to see if that fixes your problem.
Problems, GE SunSmart Digital Timer 15312 Mike Muls Electrical 41 07-30-2016 09:13 PM
Wiring GE SunSmart Digital Timer to a 3 way switch Drummer609 Electrical 25 03-04-2013 01:27 PM
Installation of a SunSmart Digital Timer PJR Electrical 4 04-26-2012 07:33 AM
GE Sunsmart Digital timer appears to be dead michaelhager Electrical 5 11-26-2011 11:52 PM
GE Sunsmart Digital Timer Installation dtn311 Electrical 1 08-01-2011 02:16 AM
