-   -   gas range outlet (http://www.diychatroom.com/f18/gas-range-outlet-159047/)
skinut2234 10-05-2012 11:46 AM
gas range outlet
Got the fridge outlet done- Now I'm looking at where the new gas range will go- (but the wife hasn't picked one out yet!)- In any event- I was looking at the specs for the more common brands out there and many of them require a 20 amp dedicated outlet. One model tells you "about" where to install the outlet, but since we have yet to pick out the model- is there a good "rule of thumb" as to where to install the outlet in relation to the gas line etc???
gregzoll 10-05-2012 12:06 PM
I run my stove outlet off of the Kitchen baseboard outlet circuit. Same for the fridge. No need to go over kill, unless your AHJ says otherwise on circuit layout.
Trane 10-05-2012 02:37 PM
You use a 3rd circuit for the general wall receptacles in a kitchen instead of one of the SABC's?
electures 10-05-2012 04:03 PM
Center of the space. Hammer handle high. I run all receptacles in the kitchen off the two SABC's.
gregzoll 10-05-2012 10:43 PM
Any circuit that uses a 20 amp breaker in the Kitchen is a SABC. There are 4 20 amp circuits in my Kitchen. 1 that serves the microwave, 1 that serves baseboard outlets, 1 that serves one counter set of outlets, 1 that serves the other counter on the other side of the Kitchen.
If I wanted to, I could have just served on side of kitchen baseboards off of the same circuit that serves the counter on that side, and same for the other side of the Kitchen. Have to love the NEC, since counters & baseboards in Kitchen & Dining, can feed off of the same circuit here in the U.S., but as things go, you always need a extra circuit or two to keep things from tripping breakers. Especially during Football season, when you have a crockpot, microwave, and countertop steam cooker running at the same time.
stubborn1 10-06-2012 07:50 AM
20A dedicated circuit for a gas range seems like overkill. In my last two kitchen remodels, I installed a single 20A circuit for the range and over the range microwave. I also located the range receptacle a little higher so you don't have to struggle to get around the range to unplug it for service. Top of box was about 30" off the floor in center of range.
That being said, the manufacturer made a recommendation for a reason - look in the literature and find the total amp draw for the appliance.
